Question about Kenmore Dryers
Dryer won't turn on. No noises prior to not working.
  • 24 Answers
The door switch does more than turn on the light when you open the door.. It also allow's some to activate the motor circuit thus when you open the door it stops.. the points inside this switch can go bad like the points on an old car and when they do from moisture they make no contact.. check it with a meter from the inside..
Posted on May 17, 2008
Frigidaire model fex831cso serial xe34800123
Hello friend, we appreciate your post!
It appears you have a laundry center FEX831CS0 and that your dryer is not working. Can you provide me more specific details? Is your dryer not heating, not turning on, or not completing a cycle? For instance did you notice any strange functions or odd noises prior to this issue? With this information I can better address the issue at hand. Thank you - Matt
Jul 19, 2014 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire dryer not working drum won't spin,
Hi How old is it , ? and dose it soun like the motor is running but not turnning the drum ? this would be a bad belt , you will need to do some more investagating for me to help you
Dec 06, 2011 | Frigidaire Dryers
Dryer won't turn over/start. When push start switch makes noise but won't turn. If hold door closed switch and turn manually while pushing start button it would work for awhile, but that has...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 05, 2011 | Amana Dryers
My dryer won't heat up to dry the clothes. I empty the condensing unit (the long many paneled pull-out piece behind the two red levers behind the lower front panel) periodically and this is not the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 23, 2011 | Asko T721 Electric Dryer
Dryer heats however will not turn, prior to it stopping it was making a loud squealing noise for weeks
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Feb 12, 2011 | Maytag MDE308DAYW Electric Dryer
I recently moved & prior 2 moving the dryer ran fine. After the move when I hooked the dryer up & turned it on it makes a loud sound almost some kind of grinding or alarm. It then shuts itself off....
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 25, 2010 | GE Dryers
Hoover Dryer has stopped completely, no prior motor noise/smell
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 27, 2010 | Hoover HDC7FM Dryer
Dryer noise and no motor action
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 03, 2010 | Maytag PYE2300AY Electric Dryer
Kenmore gas dryer runs but not heating
Try replacing the valve coils first, then the valve if the prior doesn't work. If there is a buzzing noise, I believe it's more likely the valve. I'm replacing both on mine to be sure.
Aug 18, 2008 | Kenmore Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
