Question about Swisher Zt2560 Zero Turn Radius 60" Riding Mower
My swisher zt blows the fuse every time i engage the blades...can get the engine to run and drive. problem is only when i start the blades. any ideas?
  • 4 Answers
Check the all wiring from the engage blade button back to the electric clutch for worn spots that may be grounding out on the frame.
Posted on Sep 22, 2010
What causes fuse to blow every time I try to engage blades?
To engage the blades is it a knob to an electric switch that you pull?
If so does the wire from the switch activate a electric clutch?
Is the wire damaged and shorted to the frame, is the clutch shorted. If you provide the brand name and model number I might be able to find a schematic for your mower.
Video shows an electric clutch but yours may be different but this should give you an idea of where to look. Riding Mower Electric PTO Clutch Won Engage When Hot Problem Fix
Oct 02, 2014 | Garden
Can a bad battery cause clutch to slip?
Not likely. But to eliminate that possibility try connecting a battery charge to the battery and try engaging the blades then. Also check all electrical connection in system for corrosion and tightness. Lastly With compressed air blow all dirt and debris from the mower, especially clutch area and Hydraulic pumps. Check tension on blade drive belt.
Aug 17, 2014 | Swisher Garden
I got alot of vibration when i engage the blades on my 44 inc swisher rough cutter
I had the same problem twice. The first time happened when the blades were not swinging freely because they got gummed up with grass. So make sure your blades pivot easily.
The second time happened when the nuts came loose from the blade driver (the part underneath the deck that the large bolt goes through to hold on the blade assembly). I had taken the Swisher to a small engine repair place for servicing. They removed the blade assembly to sharpen the blades while it was there but put the old lock nuts back on without using any Locktight, so the nuts started to come off while I was cutting. Unfortunately, I did not notice this until after the blade driver got very loose and then got reamed out by the wobbling of the large blade assembly bolt. I had to replace the blade driver and its bolts and nuts.
May 09, 2012 | Swisher 44-Inch 12.5 HP Trailcutter...
Swisher 44" mower starts and runs but engine bogs
The engine in this machine seems to be powerful. If you can remove the belt from the pulley that drives the blade. Try turning the pulley buy hand. If it turns tight or not at all this is your problem. The unit that is the pulley to blade assembly is seized or ready to seize. Sometimes they are designed to be taken apart and repaired, and sometimes they are not. Did you check for a grease fitting within the pulley to blade unit?
I would like to hear how this works out for you. Best of luck.
Jun 13, 2011 | Swisher Atv Trail Mowers Choose Color
Mower is the Swisher ZT 2660 runs great. Blades slow then stop during cutting, I changed belts (drive & deck). Last year you advised it maybe the electric clutch. Question is that a do it yourself...
I have this mower and had this same problem. It turned out the bolts holding the motor to frame backed out and were allowing the motor to tilt, and then the belts would slip and burn up. Check all motor bolts for tight, and if not tight change bolts and lock washers. Lock washers were not originally on these mowers.
May 01, 2011 | Swisher 60" 26 Hp Zero Turn Radius Riding...
My swisher T 60 finish mower with a 14.5 hp Briggs motor just died on me in the middle of mowing the other evening, and I assumed that I'd run out of gas. But, it had about 1/2 a tank. It starts up and...
if an electric pto , the problem is the pto is taking all of the power and robbing the ignition system
indicates a failing charging system or voltage regulator
Feb 05, 2018 | Swisher T14560 T - 60" Trailmower with 14...
Cable streched on swisher trailmower
Pull the belt cover off on the side of the engage lever and you will see that it is not a wire cable that engages the idler pulley. It's a rod connected to a long spring. Perhaps the spring came off or is defective as it puts tension on the idler pulley against the drive belt when you engage the blades. Further, there is a return spring to pull the idler pulley away from the drive belt when you disengage the blades. Check all the connections for the springs and see that the engage lever is mounted tightly. Also check the idler pulley itself.
Jun 22, 2009 | Swisher T14560 T - 60" Trailmower with 14...
Swisher Zt2560 Zero Turn Radius 60" Riding Mower Logo
370 people viewed this question
Top Swisher Garden Experts
lnbn1975
Jim Parker
Jim Parker
Tim Whalen
Are you a Swisher Garden Expert? Answer questions, earn points and help others
