Question about Toys
My Kurzweil ensemble grande mark III, purchased in 1990, has suddenly stopped working. When I switch on, there are no words in the readout and keys make no sound. What should I do?
  • 3 Answers
I had the same problem with the same piano. Your switch has gone bad so replace the on/off switch. Unplug the piano. Pry the on/off switch out with a thin blade screwdriver. With the switch in the "on" position, see if it points to the grey or brown wire & label the wire "on". Cut the wires and bring the switch to a good electronics parts store and ask for a replacement. Install & you're back in business. Or get a handyman to do it for you.
Posted on Apr 28, 2011
How do I restart when Kurzweil Mark 12 1999 piano hangs at waking up scanner message?
Hard reset procedure
1. Turn the Kurzweil off
2. Hold down the KEY START, KEY STOP, and LAYER VOLUME buttons for 5 seconds while powering the unit up, then release
3. Select RUN DIAGS
4. Press the UP arrow until the display reads RAM TEST
5. Press the START/STOP button to run the test
6. When the display reads SUCCESS, turn the unit off and back on. The unit is now reset.
If your Kurzweil still does not come up to the normal screen after this procedure, it will require service.
Apr 14, 2016 | Kurzweil Music
Owners manual for a ensemble 3 sub woffer
Try http://www.manualslib.com/manual/220406/Cambridge-Soundworks-Ensemble-Iii.html
Feb 04, 2015 | Audio Players & Recorders
Hello! I have the Kurzweil Mark Pro TWOi piano. Suddenly some keys make strange sounds through the speakers, like distrortion or noise. The speakers seem to be fine, because the demo songs play perfectly....
Try to re-initialize the unit(factory reset). If the keys are the problem then the rubber key contacts need to be cleaned or replaced. Contact a local service center for help.
Dec 09, 2014 | Music
Replacing battery in kurzweil mark 12
As per the manual it says it is located near the power switch. You will need(as per the manual instructions): a screwdriver(Phillips head), a knife, a pair of scissors, and a pair of front end wire cutters as, when shipped from the factory, the three AA batteries were taped or cable tied as a shipping precaution(to keep them from falling out). ***WARNING: MAKE 100% SURE YOU HAVE BACKED UP ALL OF YOUR SOUND PATCHES ON A FLOPPY DISK BEFORE BEGINNING THIS PROCEDURE!!! ONCE YOU START THE REPLACEMENT PROCESS, YOU HAVE ABOUT 30 SECONDS BEFORE THE BOARD LOSES ITS CHARGE AND YOUR SOUND PATCHES GET ERASED FROM THE ROM CHIP.***
Make sure you have all of the needed batteries and tools before beginning.
Hope this helps.
Nov 23, 2012 | Kurzweil Music Systems Kurzweil MARK152I...
Kurzweil eg 20 piano keys sinking
You may not have the patience level to attack it. Few ppeople do.
Sep 25, 2012 | Kurzweil Music
Original circa 1982 Kurzweil Ensemble Grand upright, has been working just fine until today. At first the (grand piano) sound had just become very distorted or seemed to have messed up sustain or echoing....
Given its age, this unit needs a little TLC. Units of that vintage used some capacitors that may have dried out a bit and need to be replaced. There are also op-amp ICs internally that may be defective. I would suggest a visit to a service shop that works on keyboards as not all do.
Keep us posted.
Dan
Dec 08, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Kurzweil digital piano unpredictable voices and volume
The contacts of various switches and keys are likely dirty. They are often conductive rubber and need cleaning with 99% isoprophly alcohol and q-tip. Clean both the conductive rubber pill and th circuit board traces they contact.
Sep 17, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Kurzweil piano keys are clicking seems to be worn out.
I don't see you doing any damage by having a look but I would get a piano tuner or repairer in to investigate the problem expertly - no slight on you. But if your Church congregation depend on it it's well worth the money.
Good Luck
Sep 02, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Kurzweil Mark 10 keyboard stopped working
Try the reset procedure on page 5 ( last page ) of this pdf document:http://www.dgaudiorepair.com/PDF%20Files/HARD%20RESET%20for%20Current%20KURZWEIL%20.pdf Hope this helps. Note the first procedure says highest white key. I'd do the second procedure.
Aug 27, 2009 | Music
Where is the fuel pump reset button on 1990 pontiac grand prix
GM cars don't use a fuel pump reset switch, they use an oil pressure fuel cut off sensor, same thing different way of doing the job, it the engine stops with the key in the on position or u loose oil pressure the fuel flow stops..
Jul 07, 2009 | 1990 Pontiac Grand Prix
Toys Logo
879 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
