Question about Whirlpool GEW9250 Electric Dryer
Kenmore he4 dryer 110.85089400
I have been told it is escentially a Whirlpool Duet Dryer
I have replace the 2 thermal fuses.... I have power to the controls
but does not start. when i push the start button nothing happens.
I would LOVE any help i could get
thanks a bunch...
- Pamela Rae
  • 2 more comments
  • Pamela Rae May 17, 2008
    I forgot I tested and I get an error 4E
    thanks again,
    - Pamela Rae
    sorry more info ...
    model # 110.85089400
  • Pamela Rae May 18, 2008
    i found the tech sheet... only has error PF 1E 2E 3E
    oooops PF E1 E2 E3
    Problem Solver:
  • 6 Answers
Judging by the date, I'd say this problem is already been repaired by a technician or someone else. The 4E code is related to the door switch. It could be a bad switch or the door not making full contact with it.
Posted on Aug 08, 2009
  • 24 Answers
What does the error code 4E mean in your manual? - If you dont have the manual look under any cover.. they usually have one inside the unit for whatever tech works on it..
Posted on May 17, 2008
Has power but won't start what's wrong?
Hi Is three sample resolution
1 electric cable broken
2 pushed bottom broken
3 thermal fuse broken
Check cable ,change pushed bottom open the standing cover , exchange thermal fuse open back dryer cover. Usually is the fuse.
Oct 16, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer will not start when pushing start button it just clicks once
This sounds like a problem with the thermal fuse blown which is wired in series with the motor. Power to the motor is terminated when the thermal fuse blows and the motor cannot run. No dryer function works when the motor cannot run. Click on the link below for the detailed instructions in troubleshooting this kind of Whirlpool Duet or Kenmore Elite dryer problem.
Troubleshooting Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Mar 23, 2011 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
THE POWER IS ON BUT WHEN I HIT START IT JUST CLICKS
You have a bad thermal fuse or a bad control board, likely. Check the thermal fuse first which is behine the bottom panel and behind the bottom duct assembly on blower housing.
Oct 11, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Duet dryer doesn't run. control panel lights up. push on button and all you hear is a click. what do i do?
No dryer function works when the motor cannot run and the common issue is a blown thermal fuse located on the blower housing and wired in series with the motor. There will be no power to the motor when the thermal fuse blows and the motor cannot therefore run. Bypass the thermal fuse and if the motor runs, the thermal use is indeed blown and needs to be replaced. Do not use the dryer with the thermal fuse blown due to fire hazards.
Disconnect power then open the dryer door and remove the lint filter. Remove the screws from the toe panel and remove the panel. Remove the screws securing the lint duct and remove the duct.
The thermal fuse can now be bypassed or replaced if necessary.
Bypass the thermal fuse by disconnecting the wires and taping them together or jumping a wire between them. Once done, plug the dryer in then start it. The thermal fuse is indeed blown and needs to be replaced if the dryer runs. The thermal fuse is part number 3390719. Reassemble the dryer in reverse order of the disassembly steps.
Oct 10, 2010 | Whirlpool Dryers
Whirlpool duet dryer will not operate all electrical is intact no breakers out
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer/control board
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Jul 26, 2009 | Dryers
Whirlpool Imperial Electric Dryer wont heat up
Check the following to address this issue.
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Jul 22, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I can't get the dryer to start
Check the following
The dryer would not start with a broken door switch. Replace the door switch if found defective.
3. Thermal fuse
4. Timer/control
Jun 01, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Whirlpool Duet Dryer stopped working
There is a set of instructions available at www.AnyoneCanFixIt.com for this problem. Specifically at:
http://www.anyonecanfixit.com/household.htm
It's a quick and easy fix.
Dec 27, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool GEW9250 Electric Dryer Logo
304 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
