Question about Apple iMac G4 Desktop
Ejecting a Stuck CD in Mac OSX - Apple iMac G4 Desktop
  • 600 Answers
  • First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu.
  • If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X.
  • Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared.
  • If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar.
  • Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder
  • Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button.
  • Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism.
  • Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray.
  • Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. )
  • If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Posted on Sep 17, 2010
Remove cd drive
Is the CD stuck inside. Try rebooting the computer and then ejecting the CD. If that does not work, turn it off, the turn it back on while holding down the CD eject button.
Jul 30, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My imac keeps ejecting movie
The movie probably sucks. Try inserting one that's more awesome, like Commando or Point Break
Oct 23, 2012 | Apple OSX 10.3 for Unix, Mac
My mac book has got a cd stuck in the disk drive, but the computer isn't registering it. i think its in upside down, and ji have tried all of the solutions form the help, but none of them...
You don't say which version of the Mac OS you're using, so I'll assume OS-X. Control-click the iTunes icon in the Dock, choose Force Quit, and then try ejecting the CD from the Finder or Disk Utility.
Or
Reboot and hold down the trackpad bar mouse button
Jul 06, 2011 | Apple MacBook Mac Notebook
Imac intel dual core dvd drive will not mountunable to load a cd or dvd it keep ejecting them. I have tried to boot with the OSX CD, but still it eject it out. I notice the problem when I tried to...
Installing Parallels should not change the way your optical drive works.
Try resetting the SMC as per the following article:
http://support.apple.com/kb/HT3964
If that doesn't work, try resetting the PRAM:
http://support.apple.com/kb/ht1379
If these do not resolve the issue you will likely need repair.
Jun 20, 2010 | Apple iMac Z0CY Desktop
Mac ibook wont boot past biue screen .keep running
Try holding down ALT while booting up and select Macintosh HD. If that doesn't work try inserting your mac osx install CD or DVD restart hold down ALT. Select the CD using the arrow keys after the CD has loaded go up to the drop down menus and go to disk utility, then click on your main boot disk (macintosh HD) and under the First AID tab (if your using osx) click verify permissions and restore permissions, then click verify disk and repair disk. Try to boot up. If this doesn't work restart leaving work mac osx CD in hold down D then follow the disk checker steps. This will tell you if there are any errors on your disk (hard drive). If there are you need to get it fixed or replaced.
Dec 20, 2009 | Apple Computers & Internet
MacBook Pro intel, CD stuck not mounting or ejecting
while restarting, push and hold your mouse button during the entire boot sequence. this will force the ejection of the cd.
Jun 02, 2009 | Apple MacBook Mac Notebook
PowerBook G4 won't eject cd by any means found on apple support
If you can hear that it's trying, it might be getting pinched while trying to eject, especially if something pressed down on the case at that spot. Try gently widening the opening with a flat head screwdriver while you are ejecting the CD. just put the driver in and twist a bit to widen the slot. Also, check to make sure that the fuzzy stuff that brushes off the disk when you insert it - and keeps out dust - hasn't been damaged. If it is partially missing, the missing part may be inside, keeping the CD from ejecting.
Apr 16, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Can't eject Install CD Mac OSX Panther
Hi GInette, sorry to hear you are having problems,
here is how you eject a disk that is stuck in the optical drive of a Mac.
Shut down the Mac.
press the power on button
VERY QUICKLY, press the mouse button, the trackpad button and hold it down firmly until the disk ejects.
This is a built-in hardware command independent of your system and always works when doe right, unless the optical drive is no longer recognized by the Mac or if something is inhibiting it's ejection.
Good luck
Mar 28, 2009 | Apple Computers & Internet
Cd stuck in cd rom
hello
in this case what you need to do
firstly do a right click on my computer adn then properties- hardware- device manager- dvd/cd rom under that you will have cd driver right click on that click on uninstall once its gone from there reboot teh machine and once it is coming back just press the cd rom key to take it out , it will come out adn take out the cd and then press again to close it
this will work
OR
ut a pin into the fine hole at the CD rom and then press the button it will come out
please rate this
Mar 26, 2009 | Apple MA589LLA Mac Desktop
Mac ejecting CDs
Is it ejecting just this particular disk? If so, it is a format the Mac doesn't recognize or the disk is damaged and the Mac can't register it.
Jun 26, 2008 | Apple MacBook PC Notebook
Apple iMac G4 Desktop Logo
433 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
