Question about LG WM2277H Front Load Washer
My front load washer will not dispense bleach or fabric softner.
We have the very same problem. Extremely frustrating, will not dispense bleach for the load intended, then it releases bleach for a load - causing bleaching on colored fabrics.
Posted on Jan 16, 2011
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 536 Answers
Are the plugs correctly connected to the terminals of
the INLET VALVE ASSEMBLY? Check the wiring on the
dispenser.
Check also that there is no build up of softener in the supply tubes.
Posted on Jul 07, 2015
  • LG Master
  • 1,103 Answers
Posted on Jul 06, 2015
murdozzz2
  • 75 Answers
SOURCE: Fabric Sofner won't dispense
hi there remove the soap drawer then remove the cover over the softener compartment you will more than likely find a blockage in the cover siphon or the down tube on the drawer
Posted on Feb 29, 2008
  • 65 Answers
SOURCE: NEPTUNE WASHER
"downy ball" is designed to open at the end of first spin that is the way to go without stopping machine. works very well and costs just a few dollars
Posted on Feb 18, 2008
eagle338
  • 4889 Answers
SOURCE: Bleach and Fabric Softner Dispenser
This is absolutely normal and you dont have to worry about it..
The reason for this:
The fabric softener compartment uses an over flow method to get the fabric softener out of its compartment and into the wash load. Water comes up underneath through a syphon tube and gently fills the fabric softener dispenser and causes it to over flow in its diluted state. The reason for this is that it is the most effective way for fabric softener to be diluted prior to hitting the clothes in the drum. Fabric softener has to be diluted before coming into contact with fabrics.
This is in contrast to how detergents dispensers work which simply flush the soap powder in to the drum by water being squirted on to it from above.
It is perfectly normal to have a fabric softener dispenser full of clean water after the wash cycle. Just lift and empty it out when you need to fill it with fabric softner for your next wash
Posted on Dec 10, 2007
ngfam1
  • 639 Answers
SOURCE: front load washer
Friend,
ngfam1 At your service!
Try opening the little holes in th softener try that may be clogged up! it's usually this
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
SOURCE: Kenmore front load washer will not dispense fabric softner
I've had this same problem and solved it by removing the detergent/bleach/softener dispenser drawer from the machine and seriously cleaning out all of the "gunk" from the drawer and from inside the drawer area on washer. Sometimes I have had to repeat the cleaning and then the fabric softener begins dispensing again. I have model # 417.43042200 but it may work on all the Kenmore front loading washers.
Posted on Apr 16, 2009
Soap, bleach, softner dispenser not working
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Dec 28, 2010 | Frigidaire ATF6000ES Front Load Washer
Bleach will not dispense
Here is a tip that I wrote about the problem I found with my fridgidaire not dispensing fabric softner. Hopefully this will help you out...
http://www.fixya.com/support/r5660917-fridgidaire_washing_machine_fabric
heatman101
Aug 20, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Help My front loading washer is not dispending
have you pulled the drawer from the machine and cleaned it thoroughly. break it down into individual pieces and clean the hell out of it. Fabric softener can build up over time and clog every crack and crevice. check also the hole the drawer goes into, water flows into the drawer mixes with f.s., bleach, etc. dilutes it and sends out the bottom.
Jun 16, 2009 | Washing Machines
My HE washer doesn't dispense the fabric softner
Try removing the dispenser cup - and washing the inner cup thoroughly- run a sanitary cycle with whites and chlorine bleach mold and mildew likes to haunt these front loaders - be sure to run a bleach hot water cycle once weekly
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Oct 28, 2008 | Washing Machines
Fabric softner is building up in dispenser
Same deal - I have to soak up all the residual water in the softener dispenser between washes. (The detergent and bleach compartments are fine).
Jun 13, 2008 | GE WSXH208A Front Load Washer
Front Load Does not dispense fabric softner and bleach
under the bottom panel of the washer on the left hand side is a tech sheet that will tell you how to fix this
Mar 05, 2008 | Frigidaire GLTF2940ES Front Load Washer
Feb 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG WM2277H Front Load Washer Logo
703 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
