Question about Fuji FinePix S20 Pro Digital Camera
Hello. my fuji s20 pro. powers up.lense moves out lcd shows menus. so does veiwfinder,the shutter button does nothing when pressed and i get black screen. also when you select record it shuts down. ive tried auto etc with no change.if its the ccd are they still repairing free? any help appreciated.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 17, 2010
I need to have a Fuji S20 Pro, and a Kodak P880 cleaned, adjusted and overall adjust to the Factory Specs.
The best way to do this is to fine a kodak certified service centre close to you for the P880 and a Fuji certified service centre close to you for the S20 Pro. But first ask them what they will charge you, because lager is expensive and it could cost almost as much as a new camera.
Oct 11, 2014 | Cameras
Can't see the shutter image on my LCD????
check the menus make sure he monitor or review setting is turned on. If the camera will show menu setting but no the play back then that should be it. If the LCD is down comletely then the camera must be sent off for repair.
Jun 25, 2010 | Fuji FinePix S5 Pro Digital Camera
LCD screen is black and cant see out of the lens. Menus are there but a pic cant be taken.
you need to turn the knob to auto on toyr right top side then be sure your memory card is in all the way.
Jun 24, 2010 | Fuji FinePix S20 Pro Digital Camera
Fuji Finepix F30 Suddenly takes only all pink screens (no image)
This sounds like one of two problems -
Either an LCD screen problem or a bad CCD sensor.
A LCD screen problem would indicate one of two of the following - it was cracked, or the cable inside is either damaged or moved out of the plug and need to be reseated.
A bad CCD sensor would show a pink screen on cameras, but would also show menus on the screen as well, do you see those? The CCD basically captures the image the lens is seeing and translates it to an image the camera can save. Generally the CCD can not be replaced separately from the lens and will require an entire lens assembly for repair.
Mar 16, 2010 | Fuji FinePix F30 Digital Camera
My Fuji Finepix S2000hd has lost all LCD fuctionality
My S1000fd has a EVF/LCD button. It is used to switch from Screen to veiwfinder. Is it possible you pressed it by mistake when the camera was turned on ?
Feb 19, 2009 | Fuji FinePix S2000hd Digital Camera
No picture in view screens ? appeture
Hi
First check whether lcd mode is one...
Thank you
Dec 21, 2008 | Fuji FinePix S20 Pro Digital Camera
Fuji s20 pro failed ccd, where can i get a replacement ccd from? how much would it cost regards steve Hi, I think I'm having the same issue as well. Just getting the snowstorm on the screen. Still takes...
I had the same problem - called Fuji in UK, they denied all responsibility. Had a rethink, checked on the web, and then called them back with the following -
Fuji USA and Canada both fix this problem under warranty
S2 pro and S700 both on their recall list for failed CCD's and the S20 pro uses the same CCD so why won't they fix it?
Lots of apologies and they fixed it for free!
Jul 30, 2008 | Fuji FinePix S20 Pro Digital Camera
Nikon d40
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon.
olly
Apr 15, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Fuji s 20 pro
CCD module failed, contact fuji, they got product recall for some camera models with faulty CCD
Mar 06, 2008 | Fuji FinePix S20 Pro Digital Camera
A little research shows me that Fuji has undergone an extensive repair recall for several Fuji models because of failed CCDs. My S20 Pro just lost it's ccd as well. For some reason it looks like the S20 was not covered in the free repair offer by Fuji. Has anyone else had a CCD problem with their S20
Jan 30, 2008 | Cameras
Fuji FinePix S20 Pro Digital Camera Logo
149 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
