Question about Home
I need to powder coat this shower handle and need to disassemble before I send it out. I don't have a clue as to how it comes apart.
    Problem Solver:
  • 15 Answers
Is there a small allen screw on the underside of handle?
Posted on Sep 17, 2010
How do I replace my shower handle and plate if it has detached from the pipe inside wall?
Now there you need a good friend with some kind of handy man knowledge...send a pic if you can , and maybe this might help clarify the proper way to fix it...
Jun 05, 2013 | Delta & Single Handle Shower Faucet
Water coming from single shower handle
It may just be a screw loose or you may need to check the washer and o-ring inside. Dont take anything apart if your not comfortable in doing that. Get someone who does.
Sep 06, 2012 | Price Pfister Home
How do i use cleaning powder
Hi Dont use the cleaning powder yet. Remove the group head shower and clean it with steel wool, then clean the group head where the shower sits with sfeel wool. Remove the filter fron the group handle and clean the under side. Also clean the group handle before you put the filter back in. You shouldn't use powder in these machines, but if you do, you need to put a blind filter (filter with no holes in it)in the group handle. If you dont have a blind filter, you can use foil to cover your filter. When you have done that, you need to add a 1/4 teaspoon of powder into the foil covered basket and lock the handle in the group head. Switch the coffee button on for a few seconds then off again.Domt take handle out yet. Repeat this on/off proceedure 5 or 6 times. Now remove the handle and flush out any powder that is left. Leaving the foil in place, lock the handle back into the group head and repeat the above proceedure. This fushes out any powder residue. Make a coffee and discard. Now your machine has bee back flushed. Again, i do not recomend using powder in these machines. The poder can back flow into the boiler. Just make sure you give it a good flush. If you clean your group head and shower weekly, you'll never need to use powder. Dazza COFFEE MACHINE TECHNICIAN
Sep 26, 2011 | Rancilio Silvia Espresso Machine
How do i disassemble this shower head to clean out the mineral deposit?
Most often the shower head will be threaded together. Use 2 strap wrenches to take it apart. The strap wrenches will not damage the finish. Do not force it if the fixture does not come apart easily. Soak the head in vinegar overnight to loosen the mineral deposits and make it easier to work with. Good Luck
Jul 12, 2010 | Grohe 27.069.EN0 Relexa Ultra Shower Head...
Need to fix a leaking delta shower faucet and need to know how to take it apart. Single handle. only turns to left for on and farther left the hotter it gets,
find the set screw on the handle loosen and remove handle, remove locking ring (a tool to do this comes with the replacement kit that you can buy from hardware store) remove the ball. You now have access to the washers and springs remove old washers and springs install new. reassemble in reverse. make sure not to overtighten locking ring.
Mar 31, 2010 | Delta & Single Handle Shower Faucet
How to dissassemble shower head
The shower head is removable with a crescent wrench and a pair of pliers, or two pair of pliers. Put electric tape where pliers will grasp to avoid scratching. The shower head is attached to the extension pipe like a regular screw on fitting, so to loosen turn counter clockwise. As far as disassembling the head itself, some are meant to come apart, others not. Use white tefllon plumbing tape to re-install.
Please rate this answer for me. Thank you.
Mar 25, 2010 | Moen & One Handle Tub & Shower Faucet
The shower head is leaking. I disassembled the
You need to pull and replace the cartridge on your shower valve most likely. It varies by Make and Model, but generally, remove the handle, remove any sleeve around the center spine, remove the round trim plate, close the service stops, remove the retaining clip or ring, and pull the cartridge straight out of the valve body by pulling on the spline... or get a cartridge puller. Then take your cartridge to the store and get a new one. Flush the valve body by slightly opening both service stops and then install the new cartridge and reverse the process.
Generally this problem occurs when sediment has torn part of the sealing o ring on the cartridge. If you send me the make/model and/or a picture I will give you the specific instructions
Oct 11, 2009 | Delta & Single Handle Shower Faucet
Delta 134900 handle Water coming out faucet and shower both
well the Diverter is not working it dose not matter the distance. when applied it should shoot the water to shower or tub if not working will come both.
Jun 15, 2009 | Delta & Single Handle Shower Faucet
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
