Question about GE (PSS26MSRSS) Side by Side Refrigerator
No water is coming from water dispenser - GE (PSS26MSRSS) Side by Side Refrigerator
    Problem Solver:
  • 15 Answers
Pull out refer. shut off water to unit. remove the hose anywhere convenient turn on water valve holding a pail under hose so you don't make a mess. if you get water out of the hose you may need a new filter which is located in back somewhere in the water hose system. if your ice dispenser is still working properly you may need some work done on the water spout valve
Posted on Sep 17, 2010
Hot water not dispensing
I ve glacier bay hot/ cold water dispenser - new product. Cold water is coming but no hot water. Water is not coming. What have I to do it is a week old machine.
Nov 20, 2013 | Vitapur Water Dispenser. Hot, Room and...
Water dispenser is not working
Does it make ice? If it makes Ice, then you have water to unit. If No Ice and No Water, check water supply. Otherwise, you could have a bad water valve. Remove valve and the line coming off of valve to water reservoir try to dispense water and if valve is good you should have water coming from valve. (have a bucket or bowl handy to catch water).
Mar 28, 2010 | GE Refrigerators
The water does not come out of the cool water dispenser and ice cubes come out when the water dispenser is pushed.
You may have an issue with the "electronic dispenser control board". Also, check your "water reservoir" located in the fresh food area (lower rear area) to ensure that the water is not frozen (if frozen, this will prevent water from dispensing at external dispenser).
Contact an appliance service company.
Feb 16, 2010 | KitchenAid Refrigerators
Water dispenser, no water coming out,already replaced filter and fill valve model #ed2fhexsb00
check electronics for dispenser behind dispenser. check for frozen water line
Feb 10, 2010 | Whirlpool Refrigerators
Water is not dispensed but icemaker is working
It's more common to be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
If it doesn't come out then disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If the water comes out then check the reservoir.It's behind the crispers in the fridge.
Sep 07, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Water Dispenser not working
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Aug 27, 2009 | KitchenAid Superba Architect KSCS25INSS...
No water comes out of dispenser of my kenmore side by side ice maker works great. what can i do without geting a repairman
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad. If water does come out
Aug 18, 2009 | Refrigerators
The frigde stopped dispensing water. I replaced the inside the fridge water filter, but it still doesn't dispense water. The ice maker is ok so it's getting water. Any ideas on what I can try next?
OR
Aug 10, 2009 | Refrigerators
Hi i have a kenmore model #58585892.the problem:
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad. If water does come out-
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws.
Jul 03, 2009 | Kenmore Refrigerators
Water Dispenser
GodofHops: The motor that you hear on the refrigerator is the water pump that carries the water to your dispenser. If no water is coming from the dispenser. You have to check 3 things: 1. If there's any water. 2. Water filter clogged. 3. Water line for dispenser clogged with minerales carried on water flow. SithPitt
Jul 04, 2007 | Frigidaire FSC23F7DSB Stainless Steel Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
61 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
