Question about Canon PowerShot A700 Digital Camera
My canon power shot A720 IS won't turn on...
I have tried changing the batteries 4 times and absolutley no power to the camera!!!
Help!!!
  • Canon Master
  • 4,738 Answers
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Posted on May 18, 2008
I need to download some pictures from my camera, Cannon Power shot A720
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Aug 04, 2011 | Canon PowerShot A720 IS Digital Camera
My Power Shot SX130 IS wont turn on... I dont know why, yesterday was working and all the sudden today I tried to Power On and doesn't do anything. I changed the batteries .... HELP!
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jul 11, 2011 | Canon PowerShot SX130 IS Digital Camera
I changed the batteries in my Power Shot A720 IS recently when the low battery warning flashed, and had taken only two photos when the warning flashed again. I moved the mode switch to playback and the...
Hi, 1st you must use alkline bat or minimum 800 mhp bat....
and if problem is not solved then cheak the bat cap and connection clean with aomthing,,,,
If any thing else contact me
Khatricamera@gmail.com
Mar 27, 2011 | Canon PowerShot A720 IS Digital Camera
The latch for the battery cover on my Power Shot A720 IS is broken. Can it be fixed?
Probably not as the cause is most likely broken molded plastic parts that where to small and thin to last very long. Seems to be a common problem on this otherwise great pocket camera. Use tap or a rubber band to keep the battery cover closed so the contacts still work. Bad design by Canon.
Jan 03, 2011 | Canon PowerShot A720 IS Digital Camera
Can you use a 4 GB memory card in the Power Shot A720 is canon camera
Yes, you should be able to use a 4GB SDHC card in the A720. The camera is specified to meet SDHC specs.
Aug 11, 2010 | Cameras
Time and date resetting constantly...
This camera has a separate date battery. Lift up the small rectangular cover next to the main batteries. A small CR1220 battery maintains the date. Replace it and you should be OK. I just discovered this on the Canon web site.
Jan 10, 2010 | Canon PowerShot A720 IS Digital Camera
Canon A720 IS does not turn on
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try. You can skip the battery comments and focus on the other suggestions in the article:
May 25, 2009 | Canon PowerShot A720 IS Digital Camera
Wont take pictures with flash
The problem is in the battery holder of the CR1220 battery.
-Take out the CR1220 battery (the little round one).
-When you replace it, put a bit of aluminum foil against the back, between the battery and the plastic holder, to make it a nice tight fit. One layer won't do it, but don't put in half the roll.
-Put it back in. Done
Using a fresh battery & clean it all with alcohol = good idea as well. Worked for me.
Wich
Apr 24, 2009 | Canon PowerShot A720 IS Digital Camera
Canon power shot a270 is lens error
try to remove battery with lens out then put battery back in. If problem is still there you can gently try to push in the lens as its going in but service is recommended.
Jan 16, 2009 | Canon PowerShot A720 IS Digital Camera
Canon Pwershot A720 Date and Time Function
If you are trying to get the date/time displayed in your images, you need to set the recording size (L, M1, M2, M3, S, Postcard) to Postcard. You also need to turn the Date Stamp on in the Recording Menu (Use the Menu button, select the recording tab -- silhouette of a camera, and scroll down to Date Stamp).
May 27, 2008 | Canon PowerShot A720 IS Digital Camera
Canon PowerShot A700 Digital Camera Logo
798 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
