Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I have an odor coming from my Whirlpool side-by-side refrigerator. I have cleaned it top to bottom, inside and out. The odor seems to be coming into the refrigerator through the fan. There is black moldy-looking water in the drip pan, but I can't get to it or remove it to clean it. I'm also not sure that is even the problem.
  • 2,973 Answers
It is the water that is emanating the odor. If you look at the back you will find a drain for this drip pan. If you cant find any then you may like to use a self made mop kind of a thing. A thin stick with some cloth tied to one end. Push it into the opening where you located to water from and dip it into the water and pull the stick and squeeze the water down. You will have to do it a number of times depending on the quantity of water in the pan. Then use a dry cloth the dry up the pan. This should remove the odor. Alternatively you can use a long rubber hose to siphon out the water. BUT, this is not a cure. To cure you may want to call a service personnel.
Posted on Sep 17, 2010
  • amypor Sep 17, 2010
    Thanks for your help, but removing the water is one small part of the problem. What is in there is black and moldy. The whole drip pan needs to be completely cleaned under water with bleach, but, for some reason, Whirlpool has decided to make it impossible to remove it. I have a service contract with a local appliance repair company, but they don't deal with "odors". I explained that it is actually a problem with the structure and performance of the fridge, but they still haven't gotten back to me.
Why does my electrolux refrigerator have a bad smell coming from inside
Hi ralexander73 - Are you referring to a plastic odor that the unit is providing? If so, this is typically caused by blocks of foam located on the sides of the evaporator coil being deformed by heat from the defrost heater which only a professional can repair. If not, what type of odor do you smell? With this information, I will be better to address the issue at hand. Thank you.
Feb 24, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Has anyone ever found out where the lettuce smell in the refrigerator is coming from. I also have the smell in my Whirlpool which is only about 4 years old.
The insulation can put out this type of odor. Check for cracks in the liner. If it appears ok, you will need to clean the inside of the cabinet. It's possible something may not have been sealed good and after awhile, could be causing an odor. Use warm water and a mild detergent to clean the cabinet. You can also use some charcoal or baking soda to draw out some of the odor.
Jan 21, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Odor coming from bottom of fridge
sound like drain blocked clean out with clorine bleach (not to be used inside frige/freezer). are you trying to grow your own pennicillin.?
Feb 11, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Smell developed in refrigerator, it is thoroughly clean
The drain is at the bottom inside the freezer section. It is possible a piece of something got behind a panel, or otherwise in a "hidden" spot. Or something is in the defrost water tray underneath and every time it defrosts, it gets wet and releases the odor again. Look in the drain pan by removing the kick plate (bottom grate under the doors) and look to see if anything is there. Use a few open boxes of baking soda in the fridge (to absorb odors), and wipe the inside with some vanilla extract. that combination will help with the odor. But the source of the odor needs to be removed first. It sometimes can be hard to find.
Jan 11, 2010 | Whirlpool GC5SHEXNS Side by Side...
Bad smell in Refrigerator and cleaned it throughly and it still stinks. Strange since it will get worse then better for no reason. I cannot find a drain in this side by side. If anyone has any ideas please...
The drain is at the bottom inside the freezer section. It is possible a piece of something got behind a panel, or otherwise in a "hidden" spot. Or something is in the defrost water tray underneath and every time it defrosts, it gets wet and releases the odor again. Look in the drain pan by removing the kick plate (bottom grate under the doors) and look in the drain pan to see if anything is there. Use a few open boxes of baking soda in the fridge (to absorb odors), and wipe the inside with some vanilla extract. that combination will help with the odor. But the source of the odor needs to be removed first.
Jan 11, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Bad odor when you open the doors of the refrigerator
The odor is coming from your drain pan under your evap coil. This is very ahrd to get to. They make a product that you can set in you fridge and let it run and it will take out odors. Google Refrigerator odors and it will take you the site that will ahve the product. rus
Nov 09, 2009 | Hotpoint HSS25GFP Side by Side...
Bad Odor in Whirlpool Conquest Refrigerator
put boxes of baking soda opened in the frig. The baking soda will absorb th odor.
Sep 21, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
MAYTAG FRIG SMELLS LIKE A DEAD ANIMAL!!
use bleach straight bleach to clean it it will usually kill any odors coming from a refrigerator clean it both inside and out
Jan 24, 2009 | Kenmore 50522 / 50524 Side by Side...
Foul odor coming from freezer. Kenmore model w/ freezer on top.
Clean the refrigerator thoroughly fresh food and freezer under all drawers. Then place charcoal briquettes in each 8 or 10 total. 4 or 5 in the bottom of the fresh food section. leave the for several days. If that doesnt take away the smell consider if a mouse may have gotten into a fan blade and well that can create a really bad smell.
Jan 10, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator odor
hi there,
the bad odour could be from the compressor, evaporator or heat exchanger. can you supply the complete model # please?
thanks.
Sep 25, 2008 | Whirlpool Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
149 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
