Question about Kenmore Refrigerators
Have a Kenmore side by side model#363.58062893 the freezer side is cooling and making ice but the refrig. side is not cooling there is some cool air but not enough to keep food cool enough. Traci
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 18, 2010
Kenmore 18tfa top freezer refrig model # 72852101 freezer works, no cool air going into the refrig part. Ice machine works fine too. fan is on.
Possible fan not blowing the air into the fresh food compartment or your freezer could be frosted up. Need more input.
Jan 29, 2011 | Kenmore Refrigerators
I have a Kenmore side by side refrig (no ice maker) Freezer works fine. The refrigerator side is not cooling. I have cleaned out the vent between the freezer and the refrigerator section by defrosting the...
Check to make sure the evap fan is running.
IF so, then let unit defrost, then turn back on, check for air comming thru top of refrig vent, if air moving ok, then let run for a few days and see if refrig warms again, if so then check for frost build up on back wall of inside freezer, if so, you have a defrost problem. With a defrost problem, defrost heater may be bad, defrost timer/electronic control may be defective. Either way, in most cases it is a defrost problem unless you don't have air moving and fan is running in this case you have a damper door problem inside air duct in refrig.
Sep 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
No cold air blowing into the refrigerator - temp too low
You have your own answer there - You have overfrosting and icing up behind the freezer, this will affect proper cooling - also if you have seperate freezer and refrigerator controls, it's possible the damper is not opening properly to let the cool air in. But in your case it sounds like a defrost problem. You will need to have a service person inspect your control board and defrost timer components - sometimes it's as simple as a board replacement due to a burnt resistor these things are the most common causes.
Good luck
Sep 25, 2009 | Kenmore Refrigerators
No air coming into refrig to cool
We pulled the back panel in the freezer and found the coils frozen. We defrosted the coils and the fridge started working. We will be getting a new timer. Thanks
May 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer and refrig part not cooling properly
You have a defrost problem. Such as timer, heater, limit switch.
Apr 26, 2009 | Refrigerators
Kitchenaid ksrj25cnst refrig does not cool but freezer is fine
sounds like you have a defrosting iss\ue here, ther is aduct on the left sideof refig wall perhaps 3/4 the way down usually behind one of the crispers its frozen over with ice not allpwing fresh food air to properly circulate, l;ook to the bottom of your freezer on the back wall is there ice on the panel?? if so your not deforsting properly there satech sheet underthe kickplate showing basic wiring and trouble shoooting guide as well
Apr 06, 2008 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Fridgedair side by side
what to you mean by defrosted fridg. was frost built up in freezer>? check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, OR you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore top freezer unit-refrig not cooling past 50degrees
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 03, 2007 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
206 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
