Question about Maytag MSD2656G Side by Side Refrigerator
Ice at bottom of freezer of MAytag MSD2756DEW
Where do i find how to check vent hose to drip pan. How do i check if it is plugged. I fell heat under my fridge, so I don't think the heating element is bad. help.
    Scholar:
  • 110 Answers
CALM DOWN . YOU ARE SUPPOSED TO FEEL HARM AIR AT THE BOTTOM OF THE RF AT THE KICK PLATE IT CALLED HEAT EXCHANGE WHICH IS A GOOD THING CAUSE WITHOUT MEANS YOUR MACHINES SEALED SYS. IS DEAD BUT THAT NOT THE CASE SO IF YOU HAVE ICE AT THE BOTTOM OF THE FREEZER THAT MEAN YOU HAVE A CLOGGED EVAP. DRAIN. TAKE TE BACK PANEL OFF THE FREEZER AND AT THE BOTTOM OF THE EVAP. COILS YOU WILL SEE THE DRAIN WHICH WILL BE FULL OF ICE , USE BOILING HOT WATER TO MELT THE ICE AND CONTINUE TO DO SO UNTIL THE DRAIN FLOW SMOOTHLY DOWN INTO THE DRAIN PAN. YOU HEATING ELEMENT IS FINE BUT YOU MAY WANT TO CLEAN YOUR CONDENSER COILS
Posted on Jun 01, 2008
Why is there Water on floor,and ice in bottom of freezer?
Under your frig there is a drip pan that's most likely full and check your drain tube also for clogs probably Iced up. You access the pan from the front bottom.
Hope this helps Mike
Jun 14, 2015 | Maytag Refrigerators
What a mess. The instruction manual (really lacking in detail) does not have part numbers or model description. Excess moisture dripping in refirgeration portion of unit (top freezer; bottom...
Yes it could, you will have to check your defrost water drain, if its plugged defrost water won't go to condensate pan under unit, instead will make its way down to refrigerator section
Jun 29, 2011 | Maytag Refrigerators
Drain freezes and bottom ices up ii have thawed it cleaned the hose and it does the same thing each time
My be that the unit is not defrosting. There is a timer that turns off the freezer and turns on a heating element to melt the ice in the cooling fins. If this does not happen the fins fill with ice and ice begins to form as the water drips down under the ice. the bottom will freeze and the top will begin to warm.
Sep 19, 2010 | Maytag Freezer MQU2057
Ice buildup in freezer drip pan and water overflow when in defrost mode. water drips out the front bottom freezer door. Maytag model msd2736gr
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 21, 2009 | Maytag MSD2736GR Side by Side Refrigerator
Side by side leaking water from under freezer side
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 15, 2009 | Hotpoint HSS25GFP Side by Side...
Water collects and freezes in bottom of Kenmore freezer of side-by-side freezer/refrigerator
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks!
Jul 15, 2009 | Jenn-Air JCD2295HES Side by Side...
Freezer ice
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 08, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Ice forming bottom of freezer leaking out the door
It is acutually a collector pan for the drain hose. When the refrigerator runs a defrost cycle (about every couple days), that pan collects the water from the ice that is melted and drains it through a hose inside the unit, to a pan under the unit. You will have to pull the back panel off the back of the freezer and melt it with either hot water or a hot blowdryer. Do it until you see the water draining freely into the bottom pan.
Oct 18, 2008 | KitchenAid Superba Architect KSCS25INSS...
Bottom of freezer has water dripping into it
A bad freezer door seal causes condensation that freezes at the bottom of the unit. I realize you said the drip pan was full of ice, but if the drain is clogged, that will happen. If that unit has the pan at the very bottom, condensation can also contribute to this.
Jun 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag MSD2656G Side by Side Refrigerator Logo
208 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
