Question about Dirt Devil Breeze Canister M082550 Bagless Vacuum
The belt keeps breaking. Like it's burning through.
  • 377 Answers
Sounds like the beater brush the belt is supposed to turn has frozen up due to debris. Remove the brush and clean all debris. At the ends of the brush will be two fasteners that hold the brush in place, be sure all debris is cleaned from these and add a small amount of WD40 where the beater brush fits into these two small holders. Turn the beater brush around these holders by hand to be sure it moves freely. Reassemble with new belt.
Posted on Sep 17, 2010
  • pwillitz Sep 21, 2010
    Thank you very much for the rating you provided me.
    I appreciate you taking time to do that.
    Regards,
    Paul
Burning smell
Something may be keeping the brush roll from spinning freely which may have caused the belt to break.
Jan 02, 2014 | Electrolux Central Vacuum
Dyson dc04 belt breaking
Is there something sticky stopping the brush from spinning freely will make the belt get hot and burn out
Jul 10, 2013 | Vacuums
Belts keep burning and breaking on turbopower 7100
If a roller brush does not rotate freely, the motor shaft spins in one place on the belt until it heats it up and breaks it. Roller brushes can become clogged on the ends, especially with pet hair. The solution is to remove the roller brush completely and inspect onder the endcaps, removing them if necessary to clean them completely. The roller brush should be reinstalled carefully, observing the upward orientation of the arrows on the end caps. Check operation before assuming that the problem has been solved
Mar 24, 2013 | Vacuums
Belt keeps burning off
Be sure the brush roller spins freely. Tear apart the end caps and get the carpet string and hair out of it for better performance and longer belt life. Nothing much else it can be.
Feb 18, 2013 | Dirt Devil Breeze Bagless VacuumVacuum
I HAVE A DYSON DC27 AND NOW IT IS MAKING A NOISE AND THE SUCTION IS NOT AS STRONG ANYMORE IT IS LIKE A SQUEALING NOISE
Check your belt & check for a blockage. Does it smell like anything is burning (like a stuck belt)?
Jul 29, 2011 | Dyson DC27 Bagless Upright Vacuum
Belt keeps breaking after only short use on vacum cleaner
Each vacuum cleaner manufacturer produces specific belts for specific machines. An incompatible belt installed on the vacuum cleaner will cause the belt to break or burn. The belt must be installed according to manufacturer directions for best performance, or the belt will chafe against the interior housing parts and break prematurely.Sharp debris, a low height adjustment setting or vacuuming up rug corners may cause the rubber belt to snap or wear prematurely. Check the height adjustment for the vacuum, and use a higher setting for plush rugs. Avoid vacuuming sharp objects and corners of the rug.
Jul 27, 2011 | Vacuums
Why do the belts keep breaking
Well the problem happens due to the belt If the belt not installed correctly, the rubber belt will grate against one of the components in the roller brush housing. The friction of the belt against the housing produces a pungent burning odor. To correct this you need a right belt, each vacuum cleaner manufacturer produces specific belts for specific machines. An incompatible belt installed on the vacuum cleaner will cause the belt to break or burn.
Good Luck!!
Thanks for using FixYa!!
Mar 26, 2011 | Bissell 3576 CleanView II Bagless Upright...
Old Hoover Convertible Upright U4109 keeps breaking belts. I just replaced the belts twice and both broke within 2 minutes.
Did you make sure the brush that the belt turns is free to move? Sometimes they get bound up and will not turn and as a result, the belts either burn or break. Remove the roller brush, clean the ends and remove any debris, lubricate the ends of the rollers where they are held by the stationary brackets and re-install with belt in correct position. Belt must be installed in the proper manner as well.
Sep 05, 2010 | Hoover Vacuums
Brush froze up and keeps breaking belts
I had the same problem but I found that I had replaced belt incorrectly. After placing one end of belt around pully, it has to be run behind the "belt disengager" which looks like a 1/2" wide metal tab just past pulley. After placing belt correctly I had no more belt, burning smell or brush problems.
Feb 25, 2009 | Bissell Upright Vacuum - The Pet Hair...
Dirt Devil Breeze Canister M082550 Bagless Vacuum Logo
297 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Jim Parker
Jim Parker
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
