Question about IT Works 3045 Digital Camera
How do I take the lock off my camera so that I can erase my photos
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 17, 2010
How do i erase internal memory
Your question is not quite clear as to which content you wish to erase; however, if you mean to erase or delete photos stored in the camera memory, here is the process.
1. Switch off camera,
2. Remove SD Card,
3. Close cover and switch on camera,
4. Go to view mode and chose what to erase. Follow the standard procedure for erasing photos. Check to confirm that photos have been deleted/ erased
5. Switch off camera again and re-insert SD card.
Hope this helps - and please check to indicate if it does!
Aug 12, 2014 | Cameras
After locking memory card, do I then unlock it to take pictures and will that then erase the memory card or can you tell me how to so
Locking the memory card prevents you from taking and adding photos to the memory card. It also prevents you from deleting photos from the memory card.
If you want to erase all the photos off the memory card. unlock the memory card, go to the camera's Menu and scroll through the settings ti Format the memory card, then format the memory card.
Apr 10, 2013 | Cameras
CAMERA WONT LET ME ERASE PHOTOS KEEPA SAYING PRTECTED CARD
There is a little lock on the card on the side... It might be switched to LOCK. Is this an SD card? Check that issue first please.
Jan 11, 2011 | Cameras
I cannot get the camera to erase, or delete all imiges. It pops back to protected, or busy. What am I doing wrong? I have erased before with no problem, but not now. I have messed with everything on it I...
Sometimes SD cards have locks on the back of them. I cant say this will fix your problem, but if the memory card is locked it will not allow you to delete the photos. If the photos are on your camera's memory, try playing with the options and see if they are protected for any miscellaneous reason.
Oct 22, 2010 | Canon PowerShot SD850 IS Digital Camera
I have a canon powershot sx200 IS and I recently went on vacation and took a lot of pictures using teh SD memory card provided with the camera. For some reason, after almost filling the card I received a...
The likely reason this keeps happening is that these cards weren't formatted in the camera when you first got them. However, don't do so just yet as formatting also erases the card. If you are using a memory card, take no more pics until you've recovered the photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that are available to help you recover your photos. This blog article reviews and outlines several of the better ones. Now AFTER you've recovered the photos, format the cards IN THE CAMERA USING THE CAMERAS FORMAT FEATURE. Look for it, it's located under the "tools" menu (look for the item stating the card's memory capacity). This should rejuvenate both cards, and prevent reoccurrence.
Aug 07, 2010 | Canon PowerShot SX 200 IS Digital Camera
I try to erase photo off my camera and it keeps saying card locked how do i unlock card
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 20, 2010 | Polaroid i532 Digital Camera
Unable to erase pics from camera after download - says "read only
There is a little slide on the memory stick that prevents it from being erased, make sure it is not in the locked position.
Apr 24, 2010 | Sony Cyber-Shot DSC-P92 Digital Camera
Card locked cant take photo
Remove the SD card from the camera and look for a tab on the left side of the card. If the tab is slid down writing/erasing is impossible. Slide the tab up and writing/erasing is possible.
Apr 06, 2009 | Canon PowerShot A520 Digital Camera
Green key shows on screen, cannot delete that photo
The key means that the picture is locked so you can not erase by accident. You need to remove the key be for you can erase the pic. If you have the manual it will tell you how. if not get me the model of camera and I will get you a manual.
Jan 18, 2009 | Olympus FE-220 Digital Camera
IT Works 3045 Digital Camera Logo
22 people viewed this question
Top IT Works Cameras Experts
Are you an IT Works Camera Expert? Answer questions, earn points and help others
