Question about IT Works 3045 Digital Camera
I am trying to erase pictures from the memory card however it says card protected and the key symbol is showing in the top left hand corner how do I take this off
    Genius:
  • 1,447 Answers
Hi
Thank you for using Fixya!
Remove the memory card, check the sides for a switch or a slider. slide it or switch it on the opposite direction. Reinsert memory card and try deleting the photos again.
Hope this help
Posted on Sep 17, 2010
My camera says my memory card is write protected. What does that mean and how do I turn it off?
Remove you SD card from its slot and look at the card. With the card's label facing you and the angled corner to the top right, look on the left edge of the card and you will see a very small slide switch and the label will probably have the word "lock" printed on it. Slide the switch upward toward the top edge of the card and the memory will work. This is called a write protect feature and it is designed to prevent you from accidentally erasing your important pictures.
Aug 07, 2013 | Nikon Coolpix L310 Digital Camera Black
I have a PNY 2 GB micro sd card that some one gave me and it had music but i tried erasing da music on da computer but it said its write coppied and i formated da memory card in my phone n erased everythin...
look at page "3/9" of this document "http://www.pqi.com.tw/upload/download/SD%20%284%29.pdf" and it will show on the lower right hand side of the picture a slot that says "write protect", move that tab to unlock the card.
BTW this is a good technical document for SD cards in general if you are interested in how they function.
Sep 01, 2011 | PNY 2GB microSD Memory Card
All of my files have gone :O
That means that the phone is not detecting the memory card.
this happens either when memory card is faulty, or when there is a problem on memory card slot contacts in phone (eg:dirt, broken contact).
Test the memory card on a computer with card reader.
If memory ccard does not work on PC, then the card is faulty, data may be lost. In that case test phone with new memory card.
If memory card is OK , try blowing into memory card slot in phone and reinsert memory card in phone after backing up your data.
If the phone does not work with more memory cards, then the phone memory card slot is defective.
Regards.
Jul 11, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Camera wont back up to memory card
Hi there.
Check to make sure the write protection is turned off on the memory card itself, the write protection tab is located on the left hand side of the card and is usually coloured white.
Good luck and thanks for using FixYa!!
May 15, 2009 | Olympus FE-20 Digital Camera
My camera says write protect and won't let me take pics
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Feb 07, 2009 | Olympus Cameras
Picture lock
Protected pictures cannot be erased using [ERASE],
[SEL. IMAGE] or [ALL ERASE], but they are all erased by
formatting.
• Go to Playback mode in the camera. Select the picture to be unlocked with the left or right arrow buttons, and to remove the protection select OFF with the up or down arrow button.
Dec 19, 2008 | Olympus FE-220 Digital Camera
Cannot take pictures anymore and lost my pictures in memory card.
SD cards have a little slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Aug 25, 2008 | Vivitar ViviCam 8300s Digital Camera
When I go to take a picture i can't get the flash to work and i get a lock symbol in the
your memory card is most likely locked, take it out and find a small button on the side, see if it is in the lock position, switch the position and try the camera to see if this fixed the problem
Jan 22, 2008 | Vivitar ViviCam 5100 Digital Camera
Hi , the only remedy to remove write proctection is to transfer or download all pictures to computer or rewritetable cd,
Format the sim card and donnot set again to write protection the picture .
Protect are located in play menu ,navigate downward you can see protect .
Dec 12, 2007 | Fuji FinePix S3000 Digital Camera
IT Works 3045 Digital Camera Logo
37 people viewed this question
Top IT Works Cameras Experts
Steve
Are you an IT Works Camera Expert? Answer questions, earn points and help others
