We have a Samsung DV3 SRS Television. This TV is supposed to be auto tune but we have now lost all our digital screens and only have TV Analog 1-5. How do we get our digital screen back.
  • Televison & ... Master
  • 1,525 Answers
Hello try going back on to the freeview menu click first time installation it should retune your freeview back in good luck
regards
shaun
Posted on Sep 17, 2010
Please can anyone help i cant tune my tv it wont pick up any channels when i auto tune it it says weak or no signal but i plugged aerial and tuned another tv and its fine
Are you trying to get over the air channels? IF you are does your TV have the digital tuner on analog? TV went digital and if you have an analog tuner will need either e new TV or converter box.
Jul 01, 2015 | Samsung 65" F9000 Series 4K Ultra HD Smart...
I am not a cable television subscriber. Nonetheless, why can't I get my local public television station when this television set tunes in all other local television stations (local ABC, CBS, NBC, Fox...
Some flat screen tv's have two inputs, one for digital and one for analog reception. If your local public television station is analog, then you'll need a signal input on the analog input.
You might try temporarily moving the input from the digital to the analog then doing a new channel scan to see if this picks up the PBS station. You'll have to rescan again, when you move your antenna lead in back to digital.
May 16, 2011 | Televison & Video
Does a samsung dv3 tv have freeview
Yes, it does.
DV3 is actually DVB meaning Digital Video Broadcasting. The stylised design of the DVB symbol makes it look more like DV3. If the TV has the DVB symbol, then it has a digital tuner and can receive digital channels, i.e. Freeview.
If you need assistance with tuning the Freeview channels or have further questions, please let me know the model number of the TV. This can be found on a label on the back of the TV.
Regards,
BElectric
Apr 24, 2011 | Televison & Video
I have a samsung dv3 television. it has started
try this with tv in standby press INFO / MENU / MUTE / STANDBY on remote the tv will come on with manufactures menu you will see RESET use ONLY DOWN NAVIGATION until reset is highlighted and PRESS RIGHT NAVIGATION this will reset all tv settings PRESS STANDBY TO EXIT and then re tune all stations
hope this helped
Nov 10, 2009 | Samsung SPN4235 42 in. Plasma HDTV
No digital channels after running auto search
Same thing with my vizio vx37l tv. Did you fix the problem bpakja? If so please let me know how.
Sep 30, 2009 | Vizio VX37L Television
How do I retune my Samsung DNLE DV3 tv for freeview?
I have a Samsung DV3 and appear to have solved the problem more by luck than judgement! I turned on, pressed the button marked D.Menu (red lettering around the middle of my remote control). I then moved down one slot to the picture of the sat dish on the screen then across to auto store and across again. I then pressed ok to start and it WORKED!!!
Good luck it worked for me!!!
Jul 17, 2009 | Televison & Video
How do I digitally tune my westinghouse TV SK32H24OS. Lost manua
The easiest way might be to unplug the power from the set for several minutes, plug it back in and then run through the setup procedure. You are specifically looking for the channel auto scan function.
Feb 25, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
KD-36FS130 Digital Set-Up?
I did not know that the Sony FS series has digital capability. This is supposed to be the most basic model of CRT flat screen TV that Sony made.
You can get a digital cable or satellite box that outputs analog baseband or component analog video and analog audio. You can then connect this box in to the TV set. The TV will then display the analog signal from the digital box.
If your cable or sat box is able to tune in standard channels, but cannot tune in the ones that are on digital service, then the fault is with the box, or the cable or sat system. This you should address to the TV service provider.
Jerry G.
Apr 19, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Toshiba D-VR650KU can't "see" digital channels
On the Notification screen with Cable highlighted I found that left clicking on Cable gave a drop down menu with TV on it for selection. The manual says that while Cable is highlighted, use the up or down arrows to get TV to be an option and then select it and Yes and enter. Hope this helps. I have other problems with my monitor on Line Out, the screen oftens turns blue indicating low or no video using Line 1 or 2 inputs.
Feb 21, 2008 | Toshiba D-VR650
Televison & Video Logo
500 people viewed this question
Top Televison & Video Experts
Electro Med Services...
