Question about Tomtom ONE GPS Receiver
Tomtom one v4
When i insert sd card and switch on it comes on but then freezes on the tom tom logo can you help thanks
  • 515 Answers
My tomtom wont disconect from the computer just gives me a red x
This means it is not reading the SD card and that it needs to be re-formatted.
This is best done in a card reader and not the tomtom itself.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH (TOMTOM HOME) if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
Then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card
It should now work
Bob
EXMod
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Jan 13, 2010 | Tomtom ONE GPS Receiver
GPS unit is stuck on the main screen, and wont turn off
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
It should now work
Dec 20, 2009 | Tomtom ONE XL GPS
Tomtom 1 v3 wont read new sd card help
Take special not of part 6
1. Remove the SD card
The card needs to be formatted properly first that's all,
2. formatting is better done in a card reader.
3. Right click on it and select format select FAT32 as the files system
4. Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
5. You now ned to select your tom tom which will also show as a drive.
6. In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
7. Then just copy ALL the files from the tom tom to your sd card
8. DO NOT USE CUT AND PASTE !
9. Once all the files are on switch off the tom tom and insert the sd card
It should now work
Sep 15, 2009 | Tomtom ONE XL GPS
Unit comes on then almost immediately getting a warning sign, like perhaps the AC cord is not working. G720 Tom
Remove the SD card
then just copy ALL the files from the tom tom to your sd card
Once all the files are on switch off the tom tom and insert the sd card and re-boot
It should now work
Sep 14, 2009 | Tomtom GPS
Won't start, seems to be a problem with the card
If you have an SD card installed then
Remove the SD card from the tomtom
The card may need to be formatted properly first or re-formatted.
Formatting is better done in a card reader.
There are differing views but this method has always worked for me.
Insert the card in the reader,. Using my computer or windows explorer right click on it and select format
Now connect the tomtom to the pc but don't let tomtom home run.
Exit TomTom Home if need be.
You now need to select your tom tom which will also show as a drive and may even show its own special icon.
then just copy ALL the files from the tom tom to your sd card.
Once all the files are on your new card switch off the tom tom and insert the sd card and re-boot the TomTom
It should now work.
If not try the hard re-set in which you would use a paperclip to reset the tomtom. there should be a tiny hole on the underside of the unti.
push the paperclip in there (not too hard) while the unit is switched on
This would cause a reset to factory defaults (you may have to set home location etc)
You may also have to switch off and re-boot again for it to take effect.
Sep 06, 2009 | Tomtom ONE GPS Receiver
When turning on the no maps appears on screen
It should now work.
Aug 28, 2009 | Tomtom One XL GPS Receiver
I have a tomtom xl and when i turn it on the unit rejects the sim card and as a on screen symbul of a man with is hand out with a red x through it .
Then just copy ALL the files from the tom tom to your sd card.
It should now work.
When I switch on my TomTom, SD card has a red cross?
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you update.
Jun 13, 2009 | Tomtom One XL GPS Receiver
Tom tom one switch on
with tomtom turned on, remove SD card and press RESET, turn off tomtom and insert SD card and start tomtom, problem solved :))
Dec 06, 2007 | Tomtom One Europe v2 GPS Receiver
Tom tom 300
"My tom tom wonts switch on. I have reset it and still it comes on with a boom boom noise and shows the 2 hands on the screen. It also shows the loading bar at the bottom, but then it just freezes and nothing happens. can anyone help please ASAP"
Sound as though your Map data card is corrupt. Remove the SD card and check it with your computer using a card reader. Backup the SD card onto your computer. You can run either chkdsk or go to the drive letter under 'My Computer' right click and select properties, then tools, then check now. You can also try starting the Tomtom with the SD card out of the unit. It should show a picture of the Tomtom with a 'X'. You can also try copying the data on the SD card to another SD card.
Sep 12, 2007 | Tomtom GO 300 GPS Receiver
Tomtom ONE GPS Receiver Logo
330 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
