Question about Maytag Washing Machines
The cold water takes almost an hour to fill the machine. The hot water fills just fine.
  • 259 Answers
Most likely your issue is with a restricted or blocked screen in your hose.
You will want to disconnect your cold water line from your machine and inspect both ends of the hose for a screen, Clean the screen if there is one and also look at the valve the hose connects too for any other blockage.
MAKE sure you run the cold water straight into the washer tub at full blast prior to re-installing the screen in the hose and re-connecting it to the washer (this will ensure that any other particles in the line are flushed out).
Also beware of the "flood stop hoses" that some stores carry as they may stop working due to the washer switching between water temperatures.
Good luck with this!
Posted on Sep 17, 2010
    Problem Solver:
  • 15 Answers
Shut off water and check screen filters on each end of the hose.
solenoid may be damaged
Simpson Espirit water not Filling
try removing your cold water hose and check to see if the screen filter has a calcium buildup or some other obstruction.  if not that then possible bas inlet valve on washer.
Aug 03, 2010 | Washing Machines
Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Nov 27, 2009 | Maytag Performa PAV2200
Washing Machine Rinse and Spin lights are on
its the problem of drum getting blocked by any clothes getting tucked up.also try to move the drum manually with the machine off.if it makes any noise its the faulty motor.or drum has lost its alignment.it needs to be reseated properly in that case. -------------- The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
Jul 23, 2009 | Tricity Bendix AW1400W Front Load Washer
Kenmore 110 Top Load Washer-cold water fills extremely slowly
No it is probably the screen that is either in the end of the hose that attaches to the machine, and/or the screen is placed so that the cone is toward the machine instead of pointing away from the machine.
If the cone is pointing towards the machine any debris in the lines would collect and eventually fill the screen cone and slow or shut off water flow.
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
Apr 01, 2009 | Whirlpool GHW9400 Front Load Washer
Hot Water runs in fine but the cold only trickles into Washer,
There are 2 hoses. Hot and cold and if the nobs are not turned wide open then it will not give you the water like you want. Check to make sure that the hot water nob is turned to were the water should come out like the cold. If not that then check the water heater and see if it is set up the way it needs to be.
Nikki2913
Dec 02, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
