Question about Scotsman Ice Maker 600LB CM3 30inW Commercial Cubed Machine
CM3 WATER DIAGNOSTICS RED LIGHT FLASHING, OFF LIGHT IS GREEN MACHINE NOT RUNNING?
2 Suggested Answers
  • 267 Answers
SOURCE: I have a scotsman CM3 with aquaarmor ice machine. There is a constant trickle of water coming from each leg. Why is the happening???
Try taking off a side or back panel and see if there is frost building up. If frost is present, it could be low on refrigerant.
If there is condensation, it could be the insulation is saturated with water allowing thermal transfer to condense water out of the air.
Posted on Feb 06, 2015
Scotsman ice machine
Check the water inlet valve water seeping through valve should be running over into bin. Replace or rebuild valve. the machine should have slowed down on production of ice also.
Jul 17, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Why Scotsman CM3 ice machine shows diagnostics water problem?
should you have any questions, Thanks John Tripp Appliance 911
First let's look through the different service manuals. CM3 Water level sense diagnosticsDOWNLOAD
Head Pressure Control Kit - CM3DOWNLOAD
Reduce Air in CM3 ModelsDOWNLOAD
Replacement of the CM3 controllerDOWNLOAD
Service Handbook to 2007 - CM/CM3DOWNLOAD . I am here should you have any questions, Thanks John Tripp Appliance 911
May 15, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Stops cycling intermittantly
Any advisory lights on, e.g. bin full? Clean all sensors and make sure dump valve isn't letting water gradually drain out
Apr 04, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman 306 flashing two red blinks
From which light the water or refrigeration? E TOf
Mar 18, 2014 | Scotsman Ice Maker 600LB CM3 30inW...
Red light flashing fast
The main reason for the Fast flashing red is with the water flow meter.
located at the back part of the machine below the power connector - its functionality can be checked in diagnostic mode .
see attached pictures
its either stuck due to in proper descaling or have corrosion in the connector contact of the flow meter.
You can fined the full service manual at Partsguru
http://www.partsguru.com/user/SERVICE%20MANUAL%20TALEA%20ODEA%20REV.03.pdf
Jul 24, 2013 | Saeco Odea Giro Plus Coffee Maker
Refrigeration light blinks green
make sure your fan and compressor is running or your condenser and evaporator is not dirty
Sep 17, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Sep 14, 2009 | Starbucks Saeco Italia Digital Barista...
All leds flashing, after cleaning program
unplug it.... for about ten minutes or so
Mar 18, 2009 | Solis Palazzo Espresso Machine
Refrigerators Logo
401 people viewed this question
Top Scotsman Refrigerators Experts
john h
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Scotsman Refrigerator Expert? Answer questions, earn points and help others
