Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
Kenmore canister switch issue
Kenmore canister
  • Model# 11623813300 . When I have the switch on the bare floor setting (beater off), it's fine. When I advance the switch to the beater-on position, the powerhead turns on, but the vacuum itself shuts off. Would seem to be an issue in the switch. What's your best guess on the part for home repair. I see a part on Sears website called pcb assembly-slide pot. Is that the guy? Thanks, Dan.
  • Posted by on
    • Anonymous Jun 05, 2008
      switch only works on 1 setting
    • bai1 Jul 14, 2008
      I have the exact same issue and wonder if you can tell me the part number to order to replace the switch??
      Thanks,
      CB
    I have the same problem and took it apart. There are two switches: one on the hose and one that activates the motor - on the right side just inside next to the motor. Took the switch apart (V-`0G-3C25-L) and found it was fried - slightly melted.
    Posted on Dec 02, 2008
    • Kanabea Dec 02, 2008
      Here's the one that I replaced -
      On-off switch, above, floor
      Part # 4368653
      $5.94
      President:
    • 1,673 Answers
    It most likely is the hose pcb. It has the switch on it, and part of it is either just dirty or bad.
    Posted on May 20, 2008
    The beater bar on my Kenmore Progressive stopped turning. I tried to clean the hair out of it, then switched it back on. The bar still wasn't turning and then it started to smoke..... lots of smoke,...
    The belt is broken.First while looking at the brushes,find the screws that hold that bottom plate on.Remove the screws and the plate comes off.This will allow you to lift the brush out of the vacuum.It is important to make note of how the brush fits in the vacuum.The new belt will fit on a groove on the brush.The other end fits on a small wheel about six inches back from the brush.
    Thank you for using Fix Ya.
    Jun 03, 2011 | Kenmore 27514 Bagged Canister Vacuum
    Bare floor selection still rotates brushes
    Your switch should have 2 different on positions. One for simple suction and one to engage the beater. The setting without the beater being engaged should be first position from off and the beater would be second position
    Jan 20, 2010 | Eureka 5849A Boss Bagless Upright Cyclonic...
    Vacuum not picking up dirt
    The neck in your power head is likely clogged. Disconnect from the wand and look inside. Also check the wand.Since you have suction on the bare floor the hose is likely not blocked.
    Sep 11, 2009 | Kenmore 22512 Bagged Canister Vacuum
    Motor won't run...beater bar does
    might be the motor.but if there is a fuse it will be inside somewhere the cord comes in.if it there you will see a wire with a tubular piece of plastic in between the wire,thats where the fuse wil be.unplug it first.on the side you will see where the two pieces snap together.but first go back to the switch and make sure all the wires are connected.one might have came off when you were putting it back together
    Apr 29, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
    Kenmore canister vac 25614
    Have you checked and made sure that the hose is COMPLETELY clear and the bag is not full?
    Feb 13, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
    Kenmore Vacuum 116.36623501 does not stay on bare floor setting
    It sounds like there is something wrong with the latching assembly. GO to the Sears Parts website and enter your Model number. Look at the parts assembly for the Nozzle, and the problem will be in one of items 12 through 17.
    Dec 27, 2008 | Kenmore 25512/ 25513 Progressive Canister...
    Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
    348 people viewed this question
    Top Kenmore Vacuums Experts
    Chris Nomland
    Chris Nomland
    Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
