Question about Nokia N73 Cellular Phone
Sir,my problem is my NOKIA N73 phone memory is 44MB..free space is 22MB so i can't download file above 22MB.throug in my mobile.
  • 4,102 Answers
Hi all you need to do is free up some memory.
go through your phone and do the following
1 delete all messages you dont need from inbox/outbox/sent/drafts
2 delete all picture messages you dont need
3 delete all ringtones you dont need, these take up loads of memory so delete all the ones you dont use, most people never use the ones you get free when you buy the phone so deleting these will free up loads of memory.
after doing the above you should have no further problems with the memory if you do give me a shout back ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 17, 2010
I am having Nokia N73 Music Edition and it showing "Not enough memory to perform operation. Delete some data first". I faced this problem many times earlier. The memory status shows Approx 44...
Hello Sir !! Welcome to Fixya !! This is nothing to worry about.Sometimes this happens because of the virus in mobile phone which doesn't allows the phone to perform required actions.You need to reset your mobile phone in an order to make it work fine: To reset the mobile phone Follow the simple steps :
  • Enter *#7370# or *#7780#
  • Then enter the security code and allow phone to perform its required action.
And you are done.It will starts working fine. If this was helpful please rate or token of appreciation will be esteemed.
Mar 31, 2011 | Nokia N73 Cellular Phone
I always get this message: Low memory delete some data. When I examined memory details this is what I found out: 44mb memory used, 167kb free memory.
sir, its due to virus attack. just follow the given steps,
1. Switch off your phone...
2. Remove SIM card & memory chip...
3. Now press & hold keys - 3,*,call green) ...
4. Then without leaving these three buttons press power button...
5. Formatting task will be started...
6. Remember its a very rare trick....
Dec 28, 2010 | Nokia N73 Cellular Phone
I have Nokia N73 ME mobile. My Phone memory total size is 44MB but it shows 11 mb only. Pls help me how to increase my phone memory.
change the software of your cell phone by taking to service center.then your problem will be solved .please don't forget to vote me.
Sep 12, 2010 | Nokia N73 Cellular Phone
My phone shows memory low, delete some data, my phone memory is full with 44mb & free space is170kb, cant receive any messages also
In ur Phone memory only 170 kb is free . so, delete some data in phone memory or change datas to the memory card. Then u can receive messages
Aug 28, 2010 | Nokia N73 Cellular Phone
Unlock Memory card - N73
The steps to unlock a password protected memory card of your mobile phone, is described below. Please follow the steps:
1. To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer, http://fexplorer.en.softonic.com/symbian/download#pathbar
2. After finished downloading, install it to your mobile phone.
3. Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
4. Run FExplorer and open the following location C:\system.
5. From the location C:\System, you will see a file named as mmcstore. Rename this file as mmcstore.txt.
6. Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
7. When you finished the above steps, you will find the password of that file
Rate me if this is helpful. Good Luck :)
May 23, 2010 | Nokia N73 Cellular Phone
N73 Cellular Phone: my nokia n73 memory low delete some data sir what ...
This problem Arises When your Phone memory(C:\ Drive) Is almost Full .normally C: Drive Has 44.4MB Space. But When it goes below 500KB,it shows
"memory low delete some data"
So delete unwanted files from phone memory using any Good File managers .One i suggest is Using "Xplore" An application for n73
Which can be downloaded Here
Or else use Phones inbuilt file manager to delete unwanted files from phone memory.
Hope this will solve your problem
(Alternate download Path Click HERE)
May 16, 2010 | Nokia N73 Cellular Phone
After i format my memory card i can't transfer mp3 files in nokia pc suite and it says that i dont have enough space available in the target folder and drive even though it's empty.... thnx im looking...
if you format your memory throug only mobile. then i suggest you that format your option first in mobile then throug your computer with help of memory card with select this "Quick Format".
Nov 23, 2009 | Nokia N72 Cellular Phone
Same problem
format your phone using manual format...
*#7370# back up contacts picture and others,removed memory card,be sure you have a fully charge battery before doing so...you should know your user code default is 12345.you might loose everything because formatting your phone will return to factory state...
Sep 07, 2009 | Nokia N73 Cellular Phone
Memory low delete some data
pls send solution this problem
thanks...............
Jun 27, 2009 | Nokia N73 Cellular Phone
Memory full?
try this. this helps me..
turn off your n73 phone. turn it on. while your mobile is booting, hold
3 + * and the green call key at your left soft key until it ask your location.. select your location and BAM! your phone is new again and 44mb is back.
note: before doing this back up your files to your memory card and remove it removed it from your phone. =) This is SAFE!
Nov 19, 2007 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
75 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
