Question about Dryers
Frigidaire Affinity Dryer
Please help! My affinity dryer door reads "dr error". We have tried everything and nothing is working. I have lots of laundry to do and the warranty expried TWO DAYS AGO! Please please help!
So my husband figured it out. We took out the book in the back and then took out the push button and we figured out that the switch inside was melted and it wasn't reading that the door was closed. He unstuck the switch and it worked again!!! Thanks anyways for your help!!
Posted on May 19, 2008
    President:
  • 1,314 Answers
Try hitting stop clear twice check the door switch see if its working also if you didnt send in your warrenty card then frigidaire dont know when you bought it if youve never had it serviced i was a factory tech for years for frigidaire so you can call them and say you bought it say a week from now and get it serviced let me know what happens
Cant open the front door seems like its locked
My frigidaire affinity dryer displays LOC - Fixya
www.fixya.com/support/t4561247-frigidaire_affinity_dryer_displays_loc
my frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please - Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer question. ... Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its ... Open Questions:.
Nov 23, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Frigidaire Affinity ATF7000E DR error code
Good Morning Friend,
I understand you are receiving a "DR" error code on your Frigidaire Affinity washer, model ATF7000E. The "DR" error code is stating that there is a possible problem with the door. This could also be a possible false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire Affinity ATF7000E Front Load...
Clear codes for affinity dryer
Hi Friend, this is Z. I am happy to assist you!
I see that you have a Frigidaire Affinity dryer and I'm presuming you are seeking information on how to clear error codes on your dryer. May I please have your model number? The serial tag, which lists your model number, is typically located on the upper front, as you open the door. With this information I can help pinpoint the exact problem. In the meantime, you can reset your dryer by either unplugging your dryer or flipping off the breaker for roughly ten minutes. This often clears most false error codes. Hope this helps!
May 21, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
(2007) Frigidaire Affinity Gas Dryer won't shut off
mybe the star button stay stuck and the dryer tinks some one is puching the star button and it will continio to run. try to open the door and it will stop and then clouse the door if the dryer star whitout pushing the star then you now the star switch is stuck. goo lock
Feb 21, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Sep 07, 2010 | Frigidaire Affinity AEQ6000WH Dryer
I try to turn my dryer on, and it has a "dr" error on the timer??? I would think that means door, but the door is shut??
press and hold select and cancel buttons together for six seconds this will reset the board.there is also a chance that the door switch is bad and not seeing the door is shut
Aug 25, 2010 | Frigidaire Affinity AEQ6000WH Dryer
Error Code "dr"
Dr means door problem, either some clothes is keeping it from shutting or the door switch is bad 1ff09a4.png
Mar 05, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Sep 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Dryers Logo
268 people viewed this question
Top Dryers Experts
