Question about Ricoh Aficio SP C811DN-DL Printer
We got rid of paper jam but now it displays SC548 - call service. How can I get rid of it. The paper jam is gone.
  • elvira_strau Sep 22, 2010
    Yes, we were able to reset the fuser unit and it is working fine now.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error SC548 is fusing installation error which is caused due to fusing unit. Please check if it's installed correctly or was not pushed in correctly. Try to push it carefully with two hands, once this is done try to reset it by following this procedure:
  1. Press the Arrows up and down button at the same time for 10 seconds then press the OK button.
  2. Then a new Menu appears and selects option 2: Engine
  3. With the arrows navigate and select option 5.
  4. After this is done press the right arrow until you see "810. SC RESET" and press OK.
  5. Press Execute, you'll see it in the screen of the printer and Press ESC until all Menus disappear and then Power it off. After 2 minutes power it back on it should work.
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 17, 2010
My workforce WF-3540 displays "PAPER JAM". I can find no jam
This sounds weird but I will post it since is solved this problem for me. Despite following all the instructions I could not get rid of the "paper jam" message on my WF3540 . In desperation I tried changing the yellow ink cartridge (which was low) and after the printer went through all its "new cartridge" routine - lo and behold the paper jam message was gone and the printer worked!
Sep 25, 2013 | Epson Workforce 1100 InkJet Plotter...
Service call SC548
SC 548 - Fusing unit set error or fusing unit installation error,differ to copier models.Try reset by open/close the front door or enter in SP mode and turn ON/OFF the copier.
Mar 25, 2013 | Ricoh Office Equipment & Supplies
I have problem with my copier aficio 450,sc548 appear,please help me solve this error
SC548 is a fusing unit installation error. The machine can not detect the fusing unit for some reason. Did you have the fusing unit out of the machine? Like to remove a paper jam? In case you do not know the fusing unit is the part that gets hot. Located right before where the paper exits the copier. It comes out the front of the machine when you have the front door open. If the front door is open it is in the upper right corner and should have a blue knob on it. Make sure this unit is all the way in. You also may have a wiring or connector issue causing this as well.
You will have to enter the service mode to reset this code.
CAUTION: Do NOT mess with this service mode in any way other than the specific function I give you. Doing so could result in damage to your machine!
Enter SP (service mode) by pressing yellow C button, then press 1 0 7 on numeric keypad and then hold down the orange C button, display will change and then from the menu select "copy SP" then type in 5801 and press #, then press "execute". Turn power off and back on. If the code is gone and the machine works then your fine. If it comes back you will need to call a servicing company and have them repair the machine.
Good Luck and Thank You for using Fixya.
May 15, 2010 | Ricoh Aficio 450 Copier
Error code SC548 wont let me do anything.
please follow the instruction and you will reset the copier:
press the follow keys in order:
1. press the yellow key[c] (clear)
2. press 1-0-7 on the number pad
3.press and hold it pressed the red key [c] (stop)
4.When on the screen will appear other menu different from the usual turn off the machine from the main switch (the red switch) and then turn it on after 5 seconds.
Please answer do this is helpful for we to know if is needed some more information.(if this was not helpful you will need to write the machine model number)
Jan 22, 2010 | Office Equipment & Supplies
Service Call SC548
fuser problem . danger . call tech
Dec 18, 2008 | Ricoh Aficio SP C811DN-DL Printer
380 Paper Jam
There could be a small bit of paper stock in sensor
near the bypass tray.
Jun 23, 2008 | Xante CL30 HSE Laser Printer
Paper wont feed then says paper jam
Got rid of my problem!
In an act of despair I started to poke around the inside of the printer with a wooden match. Especially I found a small black lever mentioned on a Dell web site (general paper jam help page) that could be pressed a little. It is placed just a little bit right of center behind the carriage and just above the roll that feeds the paper beneath the printer heads. I'm not sure if this was what finally did it, but now the paper jam problem has gone away.
Another thing I noticed is that my carriage is now moving to center when I open the top. When the paper jam error was present it always moved to the far left (so I could remove any jammed paper, I suspect)
Apr 08, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 Inkjet Printer False Paper Jam
Another thing I noticed is that my carriage is now moving to center when I open the top. When the paper jam error was present it always moved to the far left (so I could remove any jammed paper, I suspect).
Mar 30, 2008 | Dell 924 All-in-One InkJet Printer
Paper Jam Error 2
Don't try a dozen things suggested by people online who's credentials are unknown. Go straight to the source.
I had the same issue and just went to www.samsung.com - looked up my model #, downloaded the PDF manual 86 pages and did a search for that error. It had step by step picture diagram of how to clear out the jam.
I just saved the company a few hundred on a service call to our printer sales/service vender.
Oct 28, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Ricoh Aficio SP C811DN-DL Printer Logo
342 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
