Question about LG Flatron L1750S 17" LCD Monitor
Flatron F Engine menu keeps popping up in the middle of what I am doing.Displays normal menu screen?? Soooo annoying
  • elvistcb339 Sep 17, 2010
    Tried putting a pin in and pushing menu button up......did not work..still popping up.
  • 2,427 Answers
Chances are the menu button on the monitor is stuck.... now if its the one with the buttons on the inside and and a touch panel on the outer ,, cimply open it up, lift the button board up by slackening the screws a bit and that should fix the issue..
if its on the outside yu can push a pin in a small opening and push the menu button up a bit..
Posted on Sep 17, 2010
  • Rishi Roshan Ali Sep 17, 2010
    ok then you will have to pen it up and slacken the circuit board,, its a small board where the buttons are located.. while inside, remove the board and press the menu switch ,, chances are its shorting,, see if its slack ,, if so just add some solder on the points and you should be fine,, in some cases you will need to replace it,, but i would just remove it and leave it out..
My monitor's brightness menu stays always popped up
check the button which get stuck up, clean it with electronic contact cleaner.you will need to remove the back cover to access the button panel.
Oct 15, 2012 | Philips 170S6FS 17" LCD Monitor
Hi there, We have a LG Flatron W2253TQ monitor and the display is half normal, half very bright. There's a perfect line down the middle - the left half displays normal colours while the right half...
It could be some sort of "Demo" mode on the display, try going into the menu of the display and looking for settings relating to Flatron F-Engine, it has a demo mode that could be the problem. That is the most likely cause since its exactly half the screen.
May 17, 2011 | LG W2253TQ-PF Monitor
WE HAVE A BLACK BOX IN THE MIDDLE OF OUR TV AND CAN'T GET IT OFF WITH THE REMOTE
Black boxes in the middle of the screen are text boxes. Text is a part of the closed captioning feature either on your television or your cable/set top box. You would press the closed captioning button on the remote repeatedly until it displays cc off or something similar. Captioning might also be active on your cable box/set top box. There is normally a hidden menu on the cable box and that is where closed captioning is. You have to turn the cable box off. Yes I did say turn the cable box off. Then press the menu button on it and then the hidden menu will pop up. Then navigate to closed captioning and choose disable.
Nov 09, 2010 | JVC Televison & Video
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
May 28, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Navigation screen switches to menu screen w/out touching it
go to MENU --> SETTINGS --> DISPLAY --> there u can switch off the navigation key icons.
May 25, 2008 | Tomtom GO 720 GPS Receiver
LG Flatron 775FT monitor distortion
Doesn't look very good :( You can try returning to the "factory settings" in your monitor's menu. Maybe try the monitor in another computer to check whether your graphics card is faulty. But all in all it looks like a fault from the monitor :( Good Luck!
Jul 25, 2007 | LG Flatron 775FT 17" CRT Monitor
Audio Noise Problem
No, that "pop" is not normal after every sound.
Sep 12, 2005 | HP Jornada 568 Pocket PC
LG Flatron L1750S 17" LCD Monitor Logo
2,327 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
