Question about Kohler Electrical Supplies
Kohler 7cmz21-rv rv generator. The problem is it won't start. it has spark and wants to start but when you release the start switch it loses spark and power to fuel pump.i Is it possible the pc board is bad, and what is the proper diagnosis test?
mamicheddy
  • 79 Answers
SOURCE: i have a kohler rv generator that will start .
When this happens, this usually means that your genset is not creating voltage. First thing I would do is disconnect your remote start wire from the genset, this will eliminate the start switch inside the RV. For a shorted remote start switch can cause you genset to shutdown. Second, place a volt meter at a spot where you will be able to read genset voltage. If no voltage is available and your voltage regulator is new, then the problem is with either the rotor or stator. The rotor is the easiest check. You need to reach the brushes. Take a resistance reading, which should be around 20 ohms. Clean the rings and make sure there is enough length on the brushes, at least over 1/2". Next, flash the fields using a 12Vdc battery. Use rubber gloves when doing this. Place the positive side to the ring closest to the bearing and negative goes to the back ring. This is done while genset is running so be careful with rotating parts. Have a volt meter on the output wires. Once you flash the fields the voltage should increase to over 50Vac. If it does then your stator is bad since you installed a new voltage regulator. If the voltage does not increase when flashing, then the rotor is bad.
Posted on May 09, 2009
  • 153 Answers
SOURCE: electrical wiring for kohler engine
Perhaps you would enjoy the entire service manual. Here it is: http://www.asberry.net/files/TP-2379.pdf
Posted on Apr 29, 2009
  • 109 Answers
SOURCE: when I try to start my kohler rv gererator all I
I would try to charge the battery or replace it.
Posted on Jun 18, 2009
protek480
  • 1723 Answers
SOURCE: I have a 1992 Itasca Toyota RV with a electric issue
Is there power at the gen? The transfer switch may not be transferring power over from gen. Check it at the gen first thing.
Posted on Aug 06, 2009
  • 5603 Answers
SOURCE: kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
Posted on Aug 11, 2009
I have a Kohler Confidant 5, model 5ckm21 generator in my RV, serial # 326827, spec# 101228. It worked fine one evening and the next day it wouldnt stay started unless the start button stays depresse
no 14vac coming from generator to control board.--cause can be regulator board on end of generator---dirty brushes or worn out brushes==b1 and b2 winding open that outputs the 14vac--my problem was blown regulator board
Dec 05, 2012 | Kohler Electrical Supplies
Kohler generator wont stay on
Check the oil pressure switch, and oil level first. Then check rotor brushes and rotor slip rings may need polishing. If the problem is still there check stator and rotor windings
Aug 25, 2012 | Kohler Electrical Supplies
Blown fuse (input fuse) on kohler generator when i push start switch
I have a kohler rv generator voltage shows 15 after starting it blows the fuse why?
Jun 11, 2012 | Electrical Supplies
Kohler Confidant 4 puts out to much voltage
Are you running the gen and plugging in the RV at the same time? I assume it is wired right and you have a transfer switch? Are you saying the voltage is fine when the RV isn't plugged in?
Apr 15, 2012 | Kohler Electrical Supplies
Kohler Confident 7 model 7CCKM22 generator
sounds like a relay should be latching one it has started
Feb 04, 2010 | Kohler 12 kW Emergency Power System -...
Kohler confidant 4 generator will not run.
i got the same gen and with the same problem
mike
Sep 24, 2009 | Kohler Electrical Supplies
Kohler confidant 4 generator service manual and wiring diagram
Aug 11, 2009 | Electrical Supplies
Aug 05, 2009 | Electrical Supplies
When I try to start my kohler rv gererator all I
Jun 18, 2009 | Electrical Supplies
Electrical Supplies Logo
302 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
Craig Butler
Craig Butler
John Trevino
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
