Question about Hisense Televison & Video
MANUAL HYDFSR-A205E - Hisense Televison & Video
Hisense T.V HYDFSR-0076ET .looking for a universal remote code
0375,0338,0397,0341. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 25, 2014 | Televison & Video
Good day. I'm looking for the universal remote code for a Hisense HYDFSR-0076ET remote please
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Type in the brand name of your device in the search box, and press "Enter".
Universal remote controls are available at most of the electronic spare part selling shops.
HYDFSR-0072E
You probably will have to return to the original setup routine and reselect English as the preferred language.
Dec 28, 2013 | Televison & Video
Instuction maual for hitachi plasma tv model no P50X01AU
These are the only manuals available. Maybe one of them will help.
  • Hitachi P60XR01U manual for Plasma TV
  • Hitachi P60XR01E manual for Plasma TV
  • Hitachi P60X901 manual for Plasma TV
  • Hitachi P55T551 manual for Plasma TV
  • Hitachi P55H4011 manual for Plasma TV
  • Hitachi P55H401 manual for Plasma TV
  • Hitachi P50XR01U manual for Plasma TV
  • Hitachi P50XR01E manual for Plasma TV
  • Hitachi P50X902 manual for Plasma TV
  • Hitachi P50X901 manual for Plasma TV
  • Hitachi P50V702 manual for Plasma TV
  • Hitachi P50V701 manual for Plasma TV
  • Hitachi P50TP01UA manual for Plasma TV
  • Hitachi P50TP01U manual for Plasma TV
  • Hitachi P50TP01EA manual for Plasma TV
  • Hitachi P50TP01E manual for Plasma TV
  • Hitachi P50T501A manual for Plasma TV
  • Hitachi P50T501 manual for Plasma TV
  • Hitachi P50T01UA manual for Plasma TV
  • Hitachi P50T01U manual for Plasma TV
  • Hitachi P50T01EA manual for Plasma TV
  • Hitachi P50T01E manual for Plasma TV
  • Hitachi P50S602 manual for Plasma TV
  • Hitachi P50S601 manual for Plasma TV
  • Hitachi P50H401A manual for Plasma TV
  • Hitachi P50H4011A manual for Plasma TV
  • Hitachi P50H4011 manual for Plasma TV
  • Hitachi P50H401 manual for Plasma TV
  • Hitachi P50A402 manual for Plasma TV
  • Hitachi P50A202 manual for Plasma TV
  • Hitachi P42TP01U manual for Plasma TV
  • Hitachi P42TP01E manual for Plasma TV
  • Hitachi P42T501A manual for Plasma TV
  • Hitachi P42T501 manual for Plasma TV
  • Hitachi P42T01UA manual for Plasma TV
  • Hitachi P42T01U manual for Plasma TV
  • Hitachi P42T01EA manual for Plasma TV
  • Hitachi P42T01E manual for Plasma TV
  • Hitachi P42H401A manual for Plasma TV
  • Hitachi P42H4011A manual for Plasma TV
  • Hitachi P42H4011 manual for Plasma TV
  • Hitachi P42H401 manual for Plasma TV
  • Hitachi P42H01U manual for Plasma TV
  • Hitachi P42H01E manual for Plasma TV
  • Hitachi P42A202 manual for Plasma TV
  • Hitachi P42A01 manual for Plasma TV
  • Hitachi CL42PD2100 manual for Plasma TV
  • Hitachi CL37PD2100 manual for Plasma TV
  • Hitachi CL32PD2100 manual for Plasma TV
  • Hitachi 70VX915 manual for Plasma TV
  • Jan 31, 2011 | Cell Phones
    I am looking for remotes codes to program my universal comcast remote. I have a Hisense remote HYDFSR-A205EA
    You can find the remote control codes for different brands of devices from
    http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
    If none of the codes work then we have two other solutions:
    1. Searching For Your Code
    If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
    If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
    1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
    2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
    3. ENTER 9-9-1 (two blinks on the remote)
    4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
      Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
    5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
    2. Learn the buttons from the original
    Line up your original remote and the head-to-head before completing the following steps.
    1. PRESS and HOLD the SETUP button until the red LED flashes twice.
    2. PRESS 9 - 7 - 5, the red LED will flash twice.
    3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
    4. PRESS the button that will receive the learned function, the LED will flash rapidly.
    5. PRESS the button on the original remote to be learned.
    Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
    To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
    More help for programming your remote can be found here:
    http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
    Hope that helps!
    Nov 09, 2010 | Hisense Televison & Video
    How do I program my remote for U-verse television? I dont have any code numbers except this one: HYDFSR-0073
    Hi, this process might take a while, but here's how to get your remote to work:
    Manual Code Search
    1. Manually turn on the component you
    want the remote to operate.
    2. Press and hold the CODE SEARCH key
    until the indicator light illuminates.
    Then release the CODE SEARCH key.
    3. Press and release the component key
    that corresponds to the component you
    want the remote to operate (TV, VCR,
    DVD, DBS•SAT, CABLE, AUDIO
    ). The
    indicator light blinks once and then
    remains lit.
    4. Aim the remote at the component. Press
    the ON•OFF key continuously until the
    component turns off.
    Important: Because there are so many
    codes, you may have to press the
    ON•OFF key many times—possibly up
    to 200 times.
    5. When the component turns off, press
    the ENTER key to store the code.
    Auto Code Search
    1. Turn on the component you want the
    remote to operate.
    3. Press and release the component key that
    corresponds to the component you want
    the remote to operate (TV, VCR, DVD,
    DBS·SAT, CABLE, AUDIO
    ). The indicator
    light blinks once and remains lit.
    4. Aim the remote at the component and
    press the ON•OFF key once. The remote
    automatically sends every code for
    the specified component one at a time,
    with the three-second delay between
    each code. Keep the remote aimed at the
    component throughout this process.
    5. As soon as the component turns off, you
    must press the ENTER key immediately
    so the remote stores the correct
    code. If you do not press the ENTER
    key within three seconds, the remote
    sends the next code in the list, and you
    will have to start over from step 2.
    Please rate if this helps!
    Mar 17, 2009 | RCA RCU600M Remote Control
    Locked remote
    i know this may sound silly but check the batteries. now if you allready changed them and your still having the same problem check the ir signal on the remote. now all you have to do is take any camera( camera phones work just as good) hold it to the ir sender on the remote press any button on the remote and look through the view finder on the camera. you should now see a light go off on the remote through the camera. if you dont see a light then you have yourself a broken remote. if you do then its possible its the tv ir reciever. and may need to be serviced. but hoping its the remote you can always get a replacment remote for cheep.
    Jan 26, 2009 | Hisense TC24FS2H TV
    Hisense remote does not work with hisense tv
    Hope that helps!
    If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
    P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
    • "FixYa!" - The solution provides great advice on how to solve the problem.
    • "Helpful" - The solution provides useful leads that helps solve the problem.
    • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
    • "Inappropriate" - The solution has absolutely nothing to do with the problem.
    Thank you for using FIXYA!
    IrishDruid
    Apr 29, 2008 | Televison & Video
    Televison & Video Logo
    118 people viewed this question
    Top Hisense Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
