Question about Cameras
My samsung camera lens seems to be stuck in when switch the camera on it just beeps then switches back off, but you can see the lens trying to come out slighty then just going completly back in, does anybody know how to sort this problem?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 17, 2010
When starting up the lens comes out the camera beeps, the lens moves partially back, the display says date and time has been reset and then the screen goes blank/ camera switches off with lens stuck...
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 15, 2011 | Kodak EASYSHARE M1063 Digital Camera
Lens refuses to come out
hi there's a problem in lens gear maybe becuase of impact or excessive force to the said parts.try to open and clean and adjust the gear that you can found inside of the lens unit.if you can't do this try to bring to service center.
goodlukc my friend
Jul 13, 2010 | Samsung Digimax A7 Digital Camera
I have a samsung s1070 and the lens is stuck out, it makes a whirring noise like its trying to move anda few beeps but thats it. also the screen wont come on at all its just black. do you know whats wrong...
It seems your camera Lens got stuck in open condition.
This will happens due to two reason.
1) Either your camera battery got died or need to be recharged or replace. or 2) Your camera is malfunctioning and need service (repair).
To resolve the problem, follow these steps.
1) Switch the camera OFF and then ON again. (May be your camera lens is struggling to extend)
2) Remove and recharge / replace the battery, If the error does not clear, Keep battery battery out of the camera overnight, and try again the next day.
Else your device need service (repair)
good Luck and have a nice day.
Rating the solution is highly appreciated.
Apr 27, 2010 | Samsung S1070 Digital Camera
The camera is not turning on. The lens is out when it should be inside when its turned off. It keeps beeping when i try to turn it on but it will not switch on.. constantly beeping.
Sounds like you've got a lens error and the beeps are signaling your lens is stuck. With the camera laying on its back, try tapping the lens ring while pressing the start button. You may just luck out. It's about all you can do without taking your camera apart.
Dec 11, 2009 | Microwave Ovens
Lens stuck after dropping camera
Probably it can be fixed, but if the lens gears are too damaged the repair could be much expensive and you would prefer to buy a new one.
Take your camera to a qualified technician to check the price of a repair.
May 23, 2009 | Samsung Digimax S730 Digital Camera
Samsung S1065 does not turn on, beeps 3 times before powering off. Lens is extended, have checked batteries, not sure what else to do??
I had the same problem, firstly you will be able to press the button on the back to view your pictures, when you do and the camera powers up quickly press the menu button. Check that your battery settings are set to alkaline, then buy some good alkaline batteries and not cheap ones. Check that they are alkaline and not like what I did and bought panasonic zinc carbon.
This worked for me and mine would not turn on either until i changed the batteries to a good make.
Oct 01, 2008 | Gateway DC-M40 Digital Camera
Samsung NV10 heeelp!Pleeease
Not sure about the battery... that could be it and I haven't tried switching it out for a new one yet, but in the meantime I am getting around this problem my grabbing the lens with my fingers and "helping" come all the way out... just give it a little pull, a little encouragement and it will come all the way out... but the trick is that you have to do it right after you try to turn it on and before you get the beeps...
So if your lens is stuck out right now and the camera is powered off, then turn the camera on and then pull the lens out before you get the beeps... once you give it a little tug, the mechanics should take over and it will extend all the way... the LCD will come on and you'll be good to go...
Like I said, I'm having this problem too and my girlfriend suggested we change the battery... I guess that's possible, that the battery is not holding enough of a charge to push the lens all the way out... I'll investigate how much a new battery costs and then determine if I think its worth a try...
Jul 10, 2008 | Samsung NV10 Digital Camera
It dont turn on
I had the same problem. Try to turn it on, 3 beeps and then it would shut down. Screen would come on for that time. Also, the lens was stuck open. It wouldn't close.
I twisted the lens (gently) and it appeared stuck. A gentle screw motioned seemed to free it. I hit the power button and it come on, but this time no 3 beeps and shut down. I then turned it off and this time the lens retracted and closed.
So, it appears that if the lens gets stuck open, it has a shut down feature that doesn't allow the camera to go further into its operation modes. I believe this stuck open problem occured on our camera when the batteries went low.
Again, a second of gentle twisting seemed to unstick it and with fresh batteries in, it was able to operate and shut down properly.
As far as batteries, I use the rechargeable Ni-Cad 2500 mA. They last a while.
Blessings to you!
Jun 02, 2007 | Samsung Digimax S500 Digital Camera
Optio S5i Stuck Lens
Hi: First of all, with that behavior, your lens are stuck. Probably the problem was on the assembly. Try to disassemble and assemble them again. Regards
May 16, 2006 | Pentax Optio S5i Digital Camera
Cameras Logo
62 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
