Question about Pioneer DEH-P9600MP CD Player
Missing Antenna lead
I have a Pioneer DEH-P9600MP headunit, and have found that i have a missing antenna lead, the main connector is located on the main board which then comes straight out the back of the unit and the wire has a jack plug connected to it, this has been cut off for some reason maybe when it was repaired......can i purchase a new for myself?, have tried many times for sites which sell replacement parts...
    Genius:
  • 1,066 Answers
Find an unused or broken stereo, and use the one off it
Posted on May 17, 2008
Will the pioneer deh p3100ub fit a 92 civic?
Yes, it should slip right in, but I recommend you buy the adapter for the wiring harness. Look here for details and instructions are pasted below:
http://www.crutchfield.com/p_130DEH1700/Pioneer-DEH-1700.html?tp=5684
1992-95 Models
See Figure 4
Removing the radio will require removal of the front part of the center console.
The original equipment radio has a coded theft protection circuit. Before beginning removal, be sure to know the code for re-installation. The code is erased whenever the battery is disconnected or the No. 32 (7.5A) fuse from the under hood fuse/relay box is removed. When power is re-connected, the word "CODE" will be displayed and will require entry of the 5-digit code for that particular unit.
WARNING All SRS wire harnesses are covered with a yellow insulation. Read the SRS precautions found in this section and install the short connectors as described.
  1. Disable the SRS system as described in this section.
  2. Remove the center instrument panel by removing the four philips screws on the top and sides.
  3. Disconnect the 4-pin connector from the cigarette lighter.
  4. Remove the two screws, then disconnect the 16-pin connector and the antenna lead.
  5. Carefully pull the radio/cassette player out.
To Install:
  1. Plug in the 16 pin connector and install the two retaining screws.
  2. Plug in the antenna lead, the cigarette lighter and carefully install the unit.
  3. Install the center instrument panel. Re-connect power to the car, and enter the 5-digit theft protection code for the radio/cassette player.
  4. Enable the SRS system.
Aug 14, 2011 | Pioneer DEH-1700 CD Player
SUBS WONT TRUN ON
Hello fresttadefjm,
There are no subwoofer settings on the Pioneer DEH-2800MP.
You need to check the external power amplifier and the connections from the Pioneer and from the sub(s). If everything is plugged in and wired correctly, check the amp fuses, both on-board and the main power fuse (located in the amp positive lead usually near the vehicle battery).
Hope this helps.
Jul 21, 2009 | Pioneer DEH-2800MP CD Player
I can not get any AM/FM reception from my pioneer DEH-P3500.
check the antenna connector in the back. does your car have an antenna.
Jun 07, 2009 | Pioneer DEH-P3500 CD Player
Need a user manual pioneer headunit
Here you go. Go to the link and scroll to the bottom enter the security code. Good to go.
Mar 26, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
OEL display not working
YOU NEED TO REPLACE A RIBBON CABLE CALL 1 800 421 5080 IS A COMPANY NAMED PACIFIC PARTS THEY SELL THAT PART.
Mar 16, 2009 | Pioneer DEH-P9600MP CD Player
Pioneer deh - p9600mp
An install gone bad. Something is hindering free movement of the face plate open mechanism. Closely inspect the top edge of the bezel, is the face plate trim ( thin plastic ornamental frame covering the ugly aluminium mounting sleeve) snapped securely back in place? has it been fitted upside down?, is it deformed?.
May 20, 2008 | Pioneer DEH-P9600MP CD Player
DEH-P9600MP not working
make sure our face plate goes in good snap in take a q-tip clean contact from radio to face plate hope its that cheers
Jan 19, 2008 | Pioneer DEH-P9600MP CD Player
Pioneer deh-p9600mp and deh-p960mp
my 9600 gat the same problem.. been told the ribbon needs replacing they sell on ebay for about £30 or you can send ur h/u to pioneer to do but that will be more expensive..
hope this helps
Jan 15, 2008 | Pioneer DEH-P9600MP CD Player
Connecting a amp
It has a remote output if it also has RCA pre-outputs. The remote output wire is blue with a white stripe.
Sep 24, 2006 | Pioneer DEH-1630R CD Player
Pioneer DEH-P9600MP CD Player Logo
44 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
