Question about HP Pavilion F1703 17" LCD Monitor
The OSD and Brightness menu keep popping up on my sceen. The brightness is changing on its own, I found out the problem wasn't the buttons!
  • Louis Ebert Sep 17, 2010
    bongoj94, Tell us just what you found to be the problem. Was it the pc or the monitor power supply? What did you do to fix the problem? Did you buy a new monitor? 12fixlouie
    Guru:
  • HP Master
  • 452 Answers
First you are u sure ?? you should clean the button with a special liquid and then ressolder the leads if does'nt work try to flush the EEROM you can download the firmware from internet or if you have another in a good stat you can make a copy from it
Posted on Oct 12, 2010
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
Apr 17, 2016 | Princeton Digital VL173 Monitor
How do you adjust brightness on a Gateway ZX4971. There are no buttons on the monitor.
My Gateway monitor instructions refer to buttons located on the right side. The procedure calls for pressing the Auto button first to set the display image for the current screen resolution then pressing the Menu button to open the on-screen display (OSD) menu. You can move through the OSD menu to select parameters such as Picture (brightness).
Dec 18, 2014 | Gateway Computers & Internet
I turned the brightness all the way down on my vp211b - not thinking that I would not be able to see the OSD to turn it back up. How can I do a factory reset without being able to see the OSD?
PDF Manual at the link below.
http://www.viewsonic.com.au/support/manuals/files/LCD/Series%20P/VP211b-1%20User%20Guide%20English.pdf
Press MENU (Button 1)
Then DOWN Arrow followed by ENTER (Button 2)
Then DOWN Arrow followed by ENTER (Button 2) and you should be in the Brightness Menu
UP / DOWN Arrows should now change Brightness
Aug 01, 2011 | ViewSonic VP211b 21.3" LCD Monitor
My optiquest Q19wb monitor has the contrast/brightness option disabled in the menu..I am using it as my secondary monitor..OS used is win7
Try unlocking it:
http://www.fixya.com/support/r4628438-aoc_monitor_lock_unlock_instructions
1) Press the MENU-button ( ) to activate the OSD window.
2) Press or to navigate through the functions. Once the desired function is highlighted, press the MENU-button to
activate sub-menu . Once the desired function is highlighted, press MENU-button to activate it.
3) Press or to change the settings of the selected function. Press or to select another function in sub-menu .
Press AUTO( ) to exit . If you want to adjust any other function, repeat steps 2-3.
4) OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power
button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then
press power button to turn the monitor on.
5) Eco Mode hot key ( ) : Press the Eco key continuously to select the Eco mode of brightness when there is no OSD (
Eco mode hot key may not be available in all models).
6) Volume adjustment hot key : When there is no OSD , press Volume ( ) to active volume adjustment bar, press or
to adjust volume ( Only for the models with speakers).
Apr 16, 2011 | ViewSonic Optiquest Q19wb LCD Monitor
How to get rid of osd lock on screen?
Try turning the monitor off, holding the + and - buttons for brightness and contrast and turn the monitor back on release the buttons.
Next if that dosent work hold the menu button down until the osd unlocked pop up appears.
hope this helps.
Feb 04, 2010 | Computers & Internet
Brightness menu keeps popping up
This problem is usually caused due to a faulty microswitch in the brightness button. To rectify this, you'll have to change this switch.
Get your monitor serviced by a qualified service personnel.
Hope this solves your problem. For more help or clarifications, please reply. Thanks.
Aug 09, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
On the side of the monitor are 6 little buttons. What is the function of each of these buttons.
I found a user guide for a CMV938A that I expect the buttons to be the same.
Here is a link to the manual: CMV938A User Guide
The buttons are described on page 6 of the manual.
1.
Power On/Off button and indicator LED.
Green: Normal.
Orange: Power Saving.
Off: Power Off.
2.
Enter and exit the OSD menu.
3. O/>
•* Quick brightness adjustment and increase contrast/brightness.
•* Move selection right when OSD is displayed.
4. O/<
•* Quick contrast adjustment and decrease contrast/brightness.
•* Move selection left when OSD is displayed.
5 Auto/▼
• *Automatically optimize positions, phase, and clock when OSD is not displayed.
• *Move selection down when OSD is displayed.
6 Turbo/▲ •
*Switch between picture, text and economy modes.
• *Move selection up when OSD is displayed.
Nov 05, 2008 | Computers & Internet
Menu option
stuck in adjusting button?
Oct 11, 2007 | HP f1905 19" Flat Panel LCD Monitor
OSD Locked
Press menu button for 5 seconds until the text "OSD Unlocked" appears on the screen.
Aug 28, 2007 | LG Flatron L1750S 17" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
141 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
