Question about Bosch NHT645SGB Gas Cooktop
Need to know how to replace cooktop ignitor , Model NHT 725\r\nWhat type of fastener ( allen, star, metric etc )? holds the cover plate around the burner.
  • jimpelleschi Sep 18, 2010
    Need to know what type of screw head ( allen , metric, spline ) are the the three screws holding the cover platein place. Can't remove the cover plate whitout this info. Don't want to damage the srews using the wrong tool.
    Brigadier General:
  • 3,917 Answers
Oven wont turn on but top burners work
You will only need the make and model of the cooktop to order the ignitor. Open the bottom drawer below the oven to find the data plate with model & serial #'s on the front of the oven.
Apr 10, 2014 | Amana Cooktops
How to replace a cooktop drip pan
It's really simple. Remove the burner grates, removed the old drip pans, then drop in the new drip pans. You can order a new drip pan from partselect.com if you don't have one yet. Let me know how this works out and if you need any further help.
Benjamin
Nov 04, 2010 | GE Profile JGP636 Gas Cooktop
Bosche cooktop nht 725 a uc 1999 need conversion kit to go from natural gas to propane, hate to toss a good stove top need model kit order numbers
I spoke with Bosch customer service who said there is no natural to LP gas conversion kit available for the NHT 725.
Oct 05, 2010 | Bosch 30 in.NGP746UC / NGP742UC Gas...
Frequently the ignitors on our Five Star stove model #TTN033 start sparking spontaneously. The only way to stop them is to turn off the circuit breaker to the stove. Thank you Philip D. Manfredi,...
You may have a bad microswitch on one of the controls. It only takes one to be bad to cause this. Another possibility is a pinched or melted wire from one of the control microswitches to the ignitor module.
Aug 05, 2010 | Five Star TTN-033-G Stainless Steel Gas...
My smeg SE2640TC1 cooktop is cracked and we need to replace it. How do we go about doing this - (ie hardwire etc)
To replace the cooktop the first thing you need to do is turn off the breaker outside that supplies the power to the cooktop.. Then go under the cooktop in the cabinet and follow the flex power cord to the wall. Remove the cover plate on that box in the wall. un connect the wires from the wires in the wall. Next look up at the bottom of the cooktop to make sure there is no clamps that hold the cooktop to the counter top. if there is remove the. Then just lift the cooktop off the counter top. from here you just reverse the steps to put the new one in.
Good Luck
May 26, 2010 | Smeg 23 in. SA435X Electric Cooktop
GE Cooktop drop-in model # jgp328bec2bb - how to take apart the cooktop,I need to replace the spark ignitor switch harness.
Turn off the gas,unplug the power.
Take the cooktop out of the cutout and support it on the countertop.
Remove all grates and valve knobs.
Remove all screws from the valves and the burners.
Remove the burner base plates.
You may have screw on the side holding the top to the base,if so,remove these too.
The top will separate from the bottom exposing your parts.
Feb 11, 2010 | GE 30 in. JGP328 Gas Cooktop
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
the very first thing i would do here is to check the ignitor itself
under the head cap you should see two screws, once those are out you will be able to lift the burner plate, lift the burner plate, you will see, or should see the ignitor, and the wire.
i check this for voltage by unplugging the ignitor and olding the wire close to a ground, the metal body is good. Turn on the ignitor, becareful it is live. yhou shgould see a spark comming from the wire
if not check to make sure that wire is in position and on the spark module
if you do see a spark this way, just order the replacement ignitor
and install it when it arrives
appliancepartspros.com
part number AP3191250
Oct 17, 2009 | GE 30 in. JGP328 Gas Cooktop
One igniter won't work right on my gas cooktop.
If you're not getting the ignitor sparking (you should hear it) when you turn the burner knob on for that burner, it could be that either the ignitor is dirty or caked with some gunk and needs to be cleaned.
The other issue could be that the ignitor is faulty and needs to be replaced. If you want to confirm a faulty ignitor before ordering a new one, you can swap it out with one of the other ignitors on the cook top. Be sure to unplug the cook top from the outlet thou, to prevent getting a shock, as those little sparkers can give you a pretty good jolt!
Just remove the grates and burners to get at the ignitor for cleaning it. To get at the ignitor, youll need to go under the cabinet or counter that the cooktop is installed on in order to remove the ignitor and swap it with one of the other ones. You'll see that these are held in place with a retaining clip you can remove with a flat bladed screwdriver, etc.
If you find that the one that isn't working is faulty, you can order one from your local appliance service store, or get one online. www.searspartsdirect.com lists parts for almost every appliance there is, just enter in the full model number to get a parts list, etc.
Hope you find this Very Helpful and best regards!
Sep 09, 2009 | GE 30 in. Profile JGP932 Gas Cooktop
Gas burner will not completely lite
Call GE answer center 1-800-626-2000 aek for tech help. Have you Model # off your data plate ready.
May 09, 2009 | GE 30 in. JGP337 Gas Cooktop
Gas Burner ignitor is not working
Yes it should be an easy fix.
Ignitors simply go bad from time to time.
If you have a meter you can check to see if you have voltage going to the ignitor. If you do, and it isnt trying to ignite, replace the ignitor.
If you have no meter, ignitors are usually less than 30 bucks so you will not be to much in the hole by just replacing it.
If you lift the cover to access the ignitor, it should be held in by two crews, the gas tube, and a wire to the flame sensor.
Make sure you turn off all gas and electric before disassembling.
You can find ignitors at your local appliance parts supply house.
All you need is the model and serial numbers.
Dec 27, 2008 | Cooktops
Bosch NHT645SGB Gas Cooktop Logo
153 people viewed this question
Top Bosch Cooktops Experts
Paul Carew
Jay Finke
Jay Finke
steve morris
steve morris
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
