Question about Echo Garden
I have an Echo 500VL that won't start after it gets hot. I've had it since early 80's. Could it be the coil? Thanks Tom
2 Suggested Answers
  • 6468 Answers
SOURCE: Echo Chainsaw keeps cutting off
does it start and run for a min or two then die try and remove the muffler and run it if ok open the muffler and clean the screen off
Posted on May 27, 2012
What causes a chainsaw to run great until it gets hot. It then shuts off and will not restart?
Anyways.... your coil is throwing intermittent spark. Which is a sign of a coil going bad. It's basically malfunctioning when it's around severe heat. Don't bang your head against the wall bud, get a new coil assy.
Sep 30, 2015 | Poulan Pro Chain Saw 46cc 20"
Echo PE-2601 gas edger gets hot and shuts off, then after cool down starts back up
sounds like the spark plug is breaking down at hot temps. replace it. if that dont work the coil is going bad
Mar 19, 2015 | Echo Pe-2601
Acura Legend 86 wont start after initially running fine
fuel pump going out and it will not run at all
coil problem will starteasy but fail after running for a while
fuel pump relay again it is running after starting and if the relay is no good , it will not pump fuel
try having the fault codes read first then have the faulty sensor replaced
May 13, 2017 | 1986 Acura Legend
May 25, 2012 | Echo Garden
I have a 500VL saw, about 30 years old that was serviced once about 15 years ago. It starts, but then stops, as though it is starved for fuel.
a good bet your carb needs to be cleaned especially if it has been sitting for any length of time.
Sep 02, 2011 | Echo Garden
Cannot get my trimmer started.
Tom, it sounds like part of the rope has jumped off of the spool. There should be a small piece of plastic with a screw holding the spool in place. It may have worked itself loose.
Jim
Jun 07, 2009 | Echo Garden
Problems with Dura Spark ignition system on a 2.8L V6 engine, '76 - '78 Mustang/Capri
Very small help:
> ,(& what is a “ballast” resistor? Is it different from a regular resistor?).
Ballast resistors are special; they have what is known as a 'positive temperature coefficient' meaning that they increase in resistance with temperature.
This provides a very hot spark to start, then a reduction in current as the resistor warms up.
This prevented points and coils from frying from unnecessarily high current.
Early electronic ignition systems still used them, I don't think any modern car has them now.
If you have a larger public library, it might be worth a look on line (if available) or a visit to search for a manual; have found some classics there.
If you find it there - copy it, then RETURN IT! :-)
Jun 10, 2008 | Ford Mustang Cars & Trucks
Garden Logo
110 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
