Question about Apple Red Swirl Skin Case For Iphone 3gs 3g 2g
How to remove the battery from iphone - Apple Red Swirl Skin Case For Iphone 3gs 3g 2g
    Sergeant:
  • 158 Answers
You need a tool(small screw driver) the screw is located at charging pin
Posted on Sep 17, 2010
How to remove scratches from iPhone screen?
its not recondmended its a screen /lens not like regular glass where you can buff out fine scratch with toothpaste the following links show how to remove scuffs or very very fine scratches but on some creens trying to remove a scratch may cause malufunctions
I5 Phone Screen Scratch Remover Yahoo Video Search Results http://mashable.com/2014/06/28/phone-screen-scratches/#8C596Bi36aqt How To Clean and Remove Scratches on the iPhone 5 5S 6 6 Plus
Aug 11, 2016 | Apple iPhone 6
How do i open the battery of iPhone 5c
If you mean, replace the battery, its fairly simple. but you must have special screwdrivers to remove the screws, you can get these, as well as a replacement battery very cheap on ebay. here is a guide to disassembly and replacing the battery on an iphone 5c :)
http://www.imore.com/how-replace-battery-iphone-5c
Feb 22, 2015 | Apple iPhone 5c
How do i take battery out of my iphone 5 c?
Without special tools you can't take the battery out.
But I have a video where you can see how it goes.
On this site you also can order spare parts and tools if needed.
iPhone 5 Battery Replacement
Jul 18, 2014 | Apple iPhone 5
How to remove an iphone battery
Step 1:
Remove the 2 tiny screws on the bottom of the iPhone (one screw on each side of charging port).
Step 2:
Gently slide the back housing up. It should slide about 1cm up, then pull it straight back, and it should easily come off the phone.
Now you should have full access to the battery, and motherboard.
If you're removing the battery, unplug the battery plug, on the lower left side of the battery, then pull the clear tab up, and also pry the battery (ONLY with your fingers), because the battery is usually glued down.
REMEMBER: When re-installing the back housing, DO NOT tighten the screws tight, or it could crack the back housing. Only tighten the screws until they're snug, and shouldn't fall out.
Go and search Youtube on how to remove iphone Battery !
Jul 09, 2014 | Apple iPhone Smartphone
How do you take the back off an iphone 5?
you cant remove that back like you can on the iphone 4/4s.. you have to remove the screen then all internals.. you can change the glass bit on the back of the phone though they are on held in be sticky tape
Apr 28, 2014 | Apple iPhone Smartphone
Where is the imei on a iphone 4?
The ID numbers for the phone are under the battery, remove the back cover remove the battery and you will see the sticker.
Dec 29, 2011 | Apple iPhone 4 Black Smartphone
Knowing how to remove iPhone battery will take some time, but in the end, you won't have to pay a ridiculous amount of money by sending it to the manufacturer. It's going to seem like you're trying to diffuse a device, but with a little effort on your part, you will be able to remove the iPhone battery. There are three different generations of iPhones, but all batteries can be removed if you follow the steps.
The items you will need:
  • Needle or paper clip
  • Flat head screwdriver
  • Micro Phillip screwdriver
  • X-Acto knife
  • Solder
  1. You will need to take out the sim card. The sim card is located at the top of the iPhone. You will see a tiny hole; insert a needle or paper clip into the hole to release the sim card. The sim card should eject, then place it to the side.
  2. Remove the bottom casing in the back of your iPhone with a fine flathead screwdriver. Insert it in the opening and leverage it up. Work on both sides of the iPhone to leverage the casing out as to not damage the area.
  3. Take a micro Phillip screwdriver and unscrew the three screws. Set the tiny screws in a safe place where it won't get lost.
  4. Take out the aluminum casing at the back of the iPhone.This will be time consuming; you will need a thin piece of metal, something that doesn't bend. Slide the metal to the far right or left side of the iPhone and it should be underneath the aluminum casing. Use your flathead screwdriver to create leverage. Carefully lift the aluminum casing until the side of it slightly opens. Take another tool to apply it to the side and leverage it out. The casing should pop where you can use your hands to open it up.
  5. Do not force the casing out. It's connected to a ribbon; it can easily be removed by using your nail and pulling the ribbon out.
  6. You should now be able to see the battery. The battery is connected to iPhone's motherboard. You will need to use your X-Acto knife to remove the excess glue on the three wires.
  7. Use you solder to remove the wires. Start from the black wire and work your way to the end. Use tweezers to keep the wire steady so it won't touch any of wiring of the iPhone's motherboard. When all three wires from the battery has been soldered off, you can then remove it from the iPhone. :p
Dec 01, 2011 | Apple iPhone Smartphone
How to insert a sim card into a Apple iPhone 3G 16GB
Remove the battery cover, then remove the battery and you should see the SIM slot, the rest is self explanatory. Just replace the battery and cover when done and turn on your iPhone.
Sep 16, 2009 | Apple iPhone 3G
Is it possible to take out battery of iphone 3g? phone hang up
actually there is no batttery on the iphone to remove. The battery is hard wired to the phone board itself. However if you hold down the home key AND the power key down at the same time for about 15 seconds it resets your phone as if you removed and reinserted the battery.
May 02, 2009 | Apple iPhone Smartphone
Apple Red Swirl Skin Case For  Iphone 3gs 3g 2g Logo
69 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
