How can i log in to the motherboard set up utilities in toshiba qosmio G10 , like in normal pcs we press DEL , but what is the key here ???
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 79 Answers
To enter bios on qosmio, Push the ESC and the power button at the same time and do not release the esc key till the computer beeps and then select function key F1
Posted on Sep 17, 2010
M645-S4110
Procedure This bulletin documents the several different methods for gaining access to the BIOS Setup feature of most models of Toshiba computers. These setting are stored in non-volatile CMOS memory, hence the alternative term "CMOS Setup". The settings are managed by a utility program built into the computer's BIOS (Basic Input/Output System).
For Toshiba notebook PCs manufactured since the introduction of Windows XP One or more of the following methods will be effective:
F2 key method Turn the computer on. If you see an invitation to press the F2 key to enter Setup, do so. The Setup screen will appear.
Toshiba Hardware utility method Run the Toshiba Hardware utility from the Toshiba Console. It may also accessible (as 'HWSetup') from the Windows Control Panel. Changes to some of the settings will require re-starting the computer. This method is the only way to access the BIOS settings on some notebook PCs (Satellite 5000 series, for example). (For these machines, pressing and holding the F12 key immediately after powering-on the notebook will allow you to alter the notebook's boot priority.)
If the Toshiba Hardware utility is not present, try the F2 key method and the Esc key method (see below). The Toshiba Hardware utility may be downloaded from the Toshiba support website at
http://support.toshiba.com
If the computer is fully off, and/or to avoid having to re-start it (and Windows), use one or the other of the following two methods. The PC will have to be truly off (not suspended, or in standby mode, or in hibernation mode). If an external keyboard is attached to the notebook (either directly or via a docking station or a port-replicator), disconnect it until you have completed this procedure.
Esc key method Turn the computer on. If you do not see a prompt to press the F2 key, then immediately press and hold the Esc key for three seconds, and then release it. When prompted to, press the F1 key. The Setup screen will appear.
For Toshiba notebook PCs manufactured before the introduction of Windows XP One or more of the following methods are appropriate:
HWSetup method Run the HWSetup utility from the Windows Control Panel. This utility provides a relatively user-friendly way to change the BIOS settings. Changes to some of the settings will require re-starting the PC (and Windows). HWSetup was pre-installed on all but early Toshiba notebook models. If it doesn't appear as a Control Panel applet on your computer, you may be able to download it from the Toshiba Support website as part of the Toshiba Utilities package for your model.
Esc key method If an external keyboard is attached to the notebook, either directly or via a docking station or a port-replicator, disconnect it. Turn the computer on. Immediately press and hold the Esc key for three seconds, and then release it. When prompted to, press the F1 key. The Setup screen will appear. The PC will have to be truly off (not suspended, or in standby mode, or in hibernation mode) for this method to work.
TSETUP method Run the TSETUP utility, under MS-DOS. TSETUP runs correctly only when executed from a 'native' MS-DOS prompt, and with the processor running in real mode -- so not from a Windows 'DOS box', and without any memory manager software running (EMM386.EXE, HIMEM.SYS, or QEMM386.EXE, for example). TSetup was pre-installed on most early Toshiba notebook models (except for the very earliest models). It is available from the Toshiba Support website.
For Toshiba desktop PCs and servers Press and hold the F2 key immediately after turning the computer on (during the Power-on Self Test (POST)).
The link for support is here
The Th Satellite M645 S4110 Support Toshiba
Aug 11, 2014 | Toshiba Satellite Computers & Internet
Toshiba Qosmio g10 no audio with Windows 7
Thank you for keeping the rest of us informed.
Jul 03, 2012 | Computers & Internet
My Toshiba Quasimo has red vertical lines running down the screen and it will only start up in SAFE MODE. I've been told by several people that its the motherboard graphics card. Is this the case and if so...
Plug the computer into an external monitor. If the picture is normal the screen on the laptop needs replacing. If there are lines on the external monitor then its the motherboard.
Welcome to Toshiba
Oct 14, 2010 | Toshiba Qosmio G10-133 Notebook
I have toshiba Qosmio G10 I lost all My Bios information so my laptop system dont start Please help me Thanks
cant lose the bios its built into the machine itself
you can change the bios settings but not lose it
more like like a power supply, ram ,motherboard or hard drive issue
If you need more help please ask but I will need more details of your problem,
Cheers Misterdj
Apr 13, 2010 | Toshiba Qosmio G10-133 Notebook
BSOD - NV4_disp.dll - Toshiba Qosmio G10-133
Re-install Windows, at the start ofthe installation, delete the partition, the create a new partition, the do a full NTFS format.
Mar 17, 2009 | Toshiba Qosmio G10-133 Notebook
No Display
I too have the same problem any ideas from anyone would help
Apr 13, 2008 | Toshiba Qosmio G10-133 Notebook
Boot problems
hi friend
Keep pressing F2 or del soon as you start up your PC u have to go in cmos setup by perssing f2 or del key when windows stat then press it there was option in go in boot there is boot device pryority set there cd dvd rom by press f10 to save cmos settings & exit then after pc was reboot u will able to boot from cd
Apr 11, 2008 | Toshiba QOSMIO F15-AV201 Notebook
Problem with keys used to enter the cmos
For Toshiba notebook PCs manufactured since the introduction of Windows XP, one or more of the following methods will be effective:
  • Toshiba Hardware utility method: Run the Toshiba Hardware utility from the Toshiba Console. It may also accessible (as 'HWSetup') from the Windows Control Panel. Changes to some of the settings will require re-starting the computer. This method is the only way to access the BIOS settings on some notebook PCs (Satellite 5000 series, for example). (For these machines, pressing and holding the F12 key immediately after powering-on the notebook will allow you to alter the notebook's boot priority.)
  • F2 key method: Turn the computer on. If you see an invitation to press the F2 key to enter Setup, do so. The Setup screen will appear.
  • Esc key method: Turn the computer on. If you do not see a prompt to press the F2 key, then immediately press and hold the Esc key for three seconds, and then release it. When prompted to, press the F1 key. The Setup screen will appear.
For more information search on toshiba web.
Thanks
iqbal
Mar 17, 2008 | Toshiba Satellite 5005-S504 Notebook
Toshiba Qosmio G10-133 PC
hi, the problem might be with the LCD connectors, of the LCD can be bad..??
Jan 03, 2008 | Toshiba Qosmio G10-133 Notebook
Computers & Internet Logo
111 people viewed this question
David Payne
David Payne
