Question about HP Office Equipment & Supplies
I have installed HP MFP 1319f on Windows 7 Ultimate and Windows XP Proffesional, using USB cable. At first everything was working but after the reconnection the scanner can not be initialised. It is shown in the Device Manager but as i said it can not be initialized. After this even if you reinstall it is the same. If you install it on new OS them it will work only for the first time. Please help.
PcExpert
  • 293 Answers
SOURCE: Windows can't find driver for FI-5660C
THE PROPER WAY ON INSTALLING USB DEVICES 1. Do not plug in your device right away. Install all drivers and software first! 2. Reboot 3. Plug the power or turn on your USB Device 4. Plug in the USB Port. 5. Windows Will detect the Device Automatically. Finish! Hope this helps.
Posted on Sep 19, 2007
SOURCE: HP L7580 All in One Device driver reinstall on reconnecting thru USB cable
Everytime I turn on my home computer my HP Photosmart C4180 reinstalls everytime. I constantly have (Copy 1) (Copy 2) etc each time and have to keep changing the most recent as my default. Anyone know how I can solve this PLEASE!?
Posted on Feb 17, 2008
SOURCE: Lost CD for installing scanner
The thing that you need to do is go to the company site. Go to the company site that made the scanner to download the drivers. If they do not have a driver for XP then you are out of luck.
Posted on Jun 06, 2008
SOURCE: USB not working on HP NX7010
I have the same problem. No sctive USB ports, yet device manager shows ok. updated system BIOS and Intel chipset from HP site - still no good. Also removed bluetooth unit, still no good.
Turned off USB power management, still no good!
The laptop was working perfectly until this happened.
Any more suggestions?
Posted on Sep 05, 2008
rickyostrom
  • 270 Answers
SOURCE: ScanJet 5300c didn't work
Most likely the destination folder for the scanning is a shared folder with limited rights. As the administrator, reset the permissions for that folder or redirect the software to a common folder with read/write/creation etc... access.
Also, make sure you are using the HP provided drivers and not those from Microsoft.
Posted on Nov 24, 2008
After installing clean version of windows 7 ultimate 32 bit from windows 7 proffesional 64 bit my pc when ever i need to restared it dosen't I have to manual turned off and on
pci controller drivers are specific to manufacturers, you need to contact the hardware manufacturer to install new drivers for 32 bit working.
Jun 18, 2014 | HP Computers & Internet
Genius G-Pen 560 Tablet Driver won't Install on Windows 7
If you have Windows 7 Professional or Ultimate you can install XP mode and Windows Virtual PC on top of Windows 7 and run XP mode.Install the drivers on XP mode and you should be able to use your tablet.
Virtual PC and XP mode are available free of charge on the Microsoft web site. The site requires authentification to verify that your copy of Windows is genuine.
Apr 03, 2012 | Genius G-Pen 560, USB 4.5 x 6 tablet with...
My notebook computer only has USB plug and it does not has serial port plug (RS232). I bought a USB converter cable for the RS232 plug. The notebook computer reconciles the USB converter cable and not...
Tthe Capshare only works with XP or Windows 7 Ultimate which has a virtual XP inside it ( a retrofit for outdated software).. I will not work with VIsta.
Feb 13, 2011 | HP CapShare 920 Handheld Scanner
I want to install hp deskjet 3325 in windows 7 ultimate, I have driver CD which works on win xp, how to install the driver for hp printer on win 7?
Follow these steps to install the compatible driver in Windows 7.
  • Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  • From the Windows taskbar, click the Windows icon ( ), and then click Devices and Printers . The Devices and Printers window opens.
  • Click Add a printer . The Add Printer window opens.
  • Click Add a local printer .
  • Click Use an existing port .
  • Click the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
  • Under Manufacturer in the Install the printer driver window, click HP .
  • Under Printers , select the appropriate alternate driver for the product (listed in the table in the previous step), and then click Next .
  • In the Printer name text box, type the product name and then click Next . The print driver starts the installation process.
  • NOTE: The name of the alternate driver displays in the window as the default name. If you prefer, you can change the name of your product. This step is optional.
  • When the installation is complete, a message displays on the computer stating that the product was added successfully.
  • In the message window, click Finished .
  • Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  • Click Close (X ) to close the window.
Nov 04, 2010 | Computers & Internet
Can I make my HP5300C Scanjet operate on windows 7
Use windows7 Prof or Ultimate
Install XP-mode
Working in XP-mode
Install the sj664 HP software.
Though the USB device HP5300C can be found, the HP scanning software will not yet find the scanner. Because the scanner is shared between W7 and XP.
On the XP-mode taskbar disconnect the USB device HP5300C.
Then start HP Precisionscan and the scanner will function as before.
It is clear why HP does not advise this simple procedure.
Just because they did not present any clue triggered me to try it once more.
Jan Wondergem
Aug 22, 2010 | HP ScanJet 5300C Flatbed Scanner
I just put windows ultimate on my old hp laptop that initially had windows 7 and everything seems to be fine apart from the audio. At first i thought that it was the drivers but after installing the hp...
This sounds like a Compatability issue with Windows 7, check with HP to make sure your machine is compatable. You may not be able to use windows 7 on your PC. Make sure the drivers you have downloaded are the correct ones and are listed for Windows 7, vista ones should work but may not. Xp ones will definately not work
Dec 03, 2009 | HP Compaq nx9030 Notebook
Scanning from HP Laser Jet M1319f MFP, How do I scann to excel
here is the page with everything about this multi task printer.
documentation, FAQ, manuals, how to use,...
http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=en&cc=us&product=3547188&lang=en&
please rate this solution
Jan 14, 2009 | HP Pavilion dv6000z Notebook
104 people viewed this question
Seeker5211
Seeker5211
