Question about Logitech LS-21 2.1 Speakers
How connect logitech ls21 to windows7 - Logitech LS-21 2.1 Speakers
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: Logitech LS21 speakers connected to
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Posted on Feb 16, 2011
How do I raise volume on Logictech speakers Ls121
You mean LS21 speakers?
You turn the control on the separate control unit. I had similar Logitech speakers. I couldn't stand the hissss when they were turned OFF! I now have Bowers and Wilkins MM1 speakers which are amazing!
Amazon com Logitech LS21 2 1 Stereo Speaker System Electronics
Dec 17, 2015 | Audio Players & Recorders
My speakers are working but my subwoofer is not
Gently open the front grille and remove the driver. You should see if the wiring to the driver is loose.
Jun 20, 2014 | Logitech Ls21 21 Stereo Speaker System 2 X...
I want the driver of frontech multimedia speaker model no.-1820
Speakers don't require drivers. Only your sound card. Connect as instructed. Usually the green 3.5mm port is the speaker input.
Oct 03, 2012 | Logitech LS21 3-Piece 2.1 Channel...
No green light on my logitech speakers
First and foremost, did you test those speakers at the store before you bought them? There must be an ON/OFF switch somwhere on those speakers. Or maybe, the AC cable is defective or loose. Try unhooking it from your speakers then hook it back. Or did you forget to plug it in the wall electrical outlet?
Jul 13, 2012 | Logitech Audio Players & Recorders
Logitech LS21 Speaker system
Please mention the fault on the system as there was no explanation
Dec 17, 2011 | Audio Players & Recorders
Does anyone there know how to wire a Logitech LS 21 speakers, meaning what wire goes where?
Improve the Fixya.com experience for everyone by voting!
The user manual has color set-up diagrams. Click on the following link for a copy of the current user manual and all the pertinent information.Official Logitech LS21 2.1 Speaker User/Installation Download
All the best,
Ben
Jul 21, 2011 | Logitech LS-21 2.1 Speakers
I am running vista 32 bit on a dell computer. i have just bought logitech ls21 speakers. i have plugged everything together but the speakers don't work. in control panel/sounds/playback it says i have...
YES YOUR SOUND DRIVER IS NOT ISTALLED .
YOU ALSO USE THE INTERNET YOU DOWNLOAD THE NEW VERSION OF REALTEK SOUND AUDIO DRIVER AND THEN SOUND IS OPEN.
Apr 10, 2011 | Logitech LS-21 2.1 Speakers
I just bought the Ls21 external speaker system. They work but the volume is incredibly low and the sub doesn't work at all. Also it works without the plug being in. Very strange. Suggestions? Drivers? what...
OS these days are usually set up for additional hardware like speakers. But you should check the settings for the speakers from your computer first. To find out if the settings is the culprit, you can plug your speakers into another music player to test it. If the same issue arises, you may have to bring it back for exchange.
Regards
Mar 06, 2011 | Logitech Ls21 21 Stereo Speaker System 2 X...
Bas speaker has logiteck ls21 on back.sound has a
try this link
http://logitech-en-amr.custhelp.com/ci/fattach/get/329407/
if that doesnt get you there just go to logitech.com and click on support and it will lead you to there
Sep 18, 2009 | Logitech LS-21 2.1 Speakers
Logitech LS-21 2.1 Speakers Logo
1,453 people viewed this question
Top Logitech Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
JP Services
JP Services
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
