Question about Liebherr KTS 1534 Comfort Compact Refrigerator
The back of my fridge is freezing up even at temperature of 1 (it goes from 1-7. I switch it off and it defrosts itself. After an hour or so it is frozen again. I have checked the seals and all are fine.
  • 909 Answers
Thermostat is faulty. replace it and set to no.4.
Posted on Sep 17, 2010
Daewoo American Style Fridge Freezer temps go from -20 then -8 then back upto -20, is this part of the automatic defrost?
It sounds like you have been checking the temperature during the defrost cycles. There are several defrost periods over 24 hours to keep the fridge Frost Free. If the fridge doesn't go back up from -8 to -20, then you may have a problem, but it sounds like all is normal.
Also, please remember that if you freeze any unfrozen food, that this will affect the temperature for several hours, depending on how much you are attempting to freeze, just freeze small lots at a time.
I hope this helps?
Feb 23, 2016 | Daewoo Refrigerators
GE Refrigerator isn't cooling properly freezer is freezing ice
You have a defrost problem !
The fridge isn`t defrosting automatically . Although it`s likely the defrost timer motor seized , it could also be the defrost termination switch , also known as the DTS switch , (or limiter switch) ..... or the defrost heater itself .
Any one of those three will give you the exact same symptoms .
You can diagnose this problem yourself simply by emptying the fridge , unplugging it with the doors slightly open , and letting it defrost for a good 24 to 48 hours .
Plug it back in , and let it run for about 12 to 18 hours . If the temperatures are OK after that , and remain OK for a few days , the problem is exactly as I described .
A defrost timer is worth about $30 to $40 .......... a DTS about $10 to $12 ............. and a heater anywhere between $25 to $75 , depending on the model .
Jul 03, 2011 | GE Refrigerators
WE HAVE A LG GR482SF 2 DOOR REFRIDGERATOR, THE FREZER IS WORKING WELL AND EVERY THING IS FROZEN.BUT THE FRIDGE IT SELF IS NOT GETTING COLD ANY HELP THANKS JOHN.
Jul 03, 2011 | LG Refrigerators
Loosing cold just five yrss.old
unplug and defrost fridge/freezer.
you most likely have ice build up in your evaporator or collection tray. a full defrost should fix this. just unplug the fridge until it is fully defrosted.
Wiki has good instruction on how to defrost a freezer;
http://www.wikihow.com/Defrost-a-Freezer
once you have it defrosted, adjust the temperature to a mid low level for 24 hours then adjust to needed freezer fridge temperature (advise to get a thermomitor to monitor your fridge and freezer is not to high as this could freeze the lines again and your back to square one.
good luck. (remember to eat or store your perishables properly so you dont loss money on your food etc spoiling.
Jul 02, 2011 | Maytag MBB2256GES Bottom Freezer...
My fridge side by side the freezer develop a lot of ice in the back and wont defrost it supposed to defrost by it self but it wont, tried to clean the back and remove all the melted water from the back ,...
Your problem is in the defroster circuit . Most defroster circuits contain only three components. They are : a timer , a heating element , and a temperature sensing cutoff switch.
Your refrigerator defrost timer shuts down normal operation every six to eight hours and goes into the defrost cycle.
Line voltage is applied to the heating element . It heats up and melts the ice on the evaporator. Once the ice is melted, and the evaporator area warms up to a certain temperature, the temperature sensing cut off switch opens up and stops the current flow through the circuit. The timer is a running clock, so to speak , and will eventually deactivate the defrost cycle return the refrigerator to its normal operation .
Normally, the element or sensing switch will be the component to replace. Also, sometimes it can be just a bad connection in the element and sensor wire connectors.
Mar 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Sanyo Frost Free Fridge (Model SR 1031) very slow to cycle through freeze to defrost back to freeze cycle. The temp in Freezer compartment goes from -17 degrees to -1 degree then back to -17 as it takes in...
DO NOT TRY TO MODIFY TIMING CYCLE.you would need to completely modify printed circuit board and inbuilt computer......some freezers cycle around 6 to 8 hours.the temperature can only be checked say every 12 hours to get an average reading
Feb 10, 2010 | Freezers
Hoypoint ffa9op.defrosted
hotpoint ffa90, I have fridge and freezer problem, non of them are keeping the required temperature though the fridge temperature is showing the right temperature but not cold and the freezer is not freezing as it is contstant between -2 to -5 but it should be
-22, the fast freeze bottom does not fridge either, it does not take instruction.
Feb 01, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Freezer switching off on Hotpoint Iced Diamond Fridge Freezer
home refrigerators are not dsigned to work in areas where the temps will drop below about 45 f to my knowledge there is no way to help wiht this problem. Thx peyton
Jan 29, 2009 | Refrigerators
Freezer alarm keeps going off..
Mate prehaps the defrost element could be burntout thus no auto defrost and the big freeze and the alarm, when you switch off the defrost starts and the alarm resets?
Apr 28, 2008 | Refrigerators
Samsung american fridge sn 188742bp100124K
The freezer temperature ok.
The fridge keeps freezing
Dec 06, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
Liebherr KTS 1534 Comfort Compact Refrigerator Logo
292 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
