Servis M6602W Washing Machine making scratching noise as drum spinning, I believe there is something gone through the holes in the drum and rubbing along the outside. How can I get access to check? Thanks in advance
    Brigadier General:
  • 3,006 Answers
There is no easy way to access the space between the inner and outer drum, unless you count cutting a hole in the inner drum and then welding it back up again afterwards. But it's hard to do this without leaving the drum unbalanced and prone to damaging subsequent wash loads. On some machines you can gain a very limited access by removing the drain tube running from the bottom of the drum to the pump. If so then you may be able to use long forceps to remove the item but may have to rotate the drum and tip the machine back and forward as you do so. Not easy when you're beneath the machine, so get strong-armed assistance.
What most often causes this problem is one or more bra underwires and they can be really difficult to fish out again, especially if they get chewed up and bent. Eventually the underwires often get chewed up and are then small enough to pass down to the trap just before the pump, so make sure that you regularly check the trap for debris as it may damage the pump or cause blockages if left unattended. If this has caused your problem then prevention is easy: never machine wash underwired bras.
Good luck, please take a moment to rate my reply.
Posted on Sep 17, 2010
Servis 1200 very noisy in spin modes. Inner drum seems to be very loose and wobbly. Noise sounds like a roller with flat spots running on the drum, or a very bad (failed) bearing. Machine is 12 years old,...
the bearings have gone, if the drum can be split, remove complete drum and replace bearings, if you dont think its something you can do, dont attempt it, but to be honest, its realitivly easy
Sep 09, 2013 | Washing Machines
Hello, I have a front load LG TROMM WM2277HB and yesterday it wouldn't spin anymoreand there was a noise coming from inside like 2 metal cylinders were rubbing on each other. I called SEARS Serv
if the machine fails to spin and makes noise there are thee things to check .if it fails to drain the water check if something is stuck on the drain pump no 2 turn the drum with your hand and check if the drum is moving freely if not something is stuck between the drum and the housing if the bearings are faulty the machine spins but makes alot of noise towards the end of the cycle i hope this will help you.
Jan 21, 2013 | LG 4775er2002a Door Hinges for Wm2277hb...
Washing Machine making a loud whirring noise when water is filling and when the machine is spinning out
Check the motor bearings If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings and has nothing to do with issues in the rest of the washer. Check for Obstructions Sometimes coins, bra underwires and other metal objects come loose in the wash and become stuck between the tub and the drum. Using a flashlight, take a good look inside the washing machine. If you see dents, scratches or dings, that's a sign that there either are or have been items bouncing around in there that can make a horrible racket. Check for Grease Spatter A high-pitched squealing can be caused when the grease thins around the bearing that's located under the tub. Open up the washing machine and check the interior for grease spatters or spots. That could mean that the grease has thinned out around the bearing and it's making the noise because of rubbing. Check the Drum for Irregularities Spin the drum by hand, listening for the noise. If it makes the noise in the same spot with each rotation, the problem could be with the washing machine drum itself. Parts of the drum can corrode over time, leaving it vulnerable to cracks or rust.
Aug 06, 2012 | Washing Machines
Hello. Near the end of the spin dry cycle, the drum started to make a loud rubbing sound (12 minutes to go???). We shut down the washer, with a cancel, then restarted the load over again. This time we...
100% if its rubbing instead of freely rotating while you manually spin the drum your bearings have gone,You can't see it's all inclosed in a plastic shell & it is pretty much a complete rebuild pain in the neck job that you are going to recieve quote's of $500 buck's or more to do the job might be worth getting a new machine it would be more economical.GOOD LUCK
Feb 25, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
My servis washing machine makes a loud grinding noise when the water drains whilst drum turning.
could be something in the pump as opposed to drum bearing fault....Try cleaning filter/check pump blades.....
Feb 24, 2011 | LG WM2077C XL Front Load Stackable Washing...
My washer makes alot of noise during the spin cycle almost like the sound of a jet engine.
Check the drum holes carefully, this often happens when something like a bra under wire gets caught in a hole and rubs on the outer drum
Feb 03, 2011 | Maytag MAH8700A Front Load Washer
Candy washing machine smoke coming from inside
it is rubbing on spin cycle due to being out of balance.Rubbing wont occur when turning by hand.
Stop by your local hardware store for a packet of drum balancers.
Aug 16, 2009 | Washburn Electric Guitars Modelno. X10-B
Washer making rubing noise while turning
On the back of your machine you can remove the back panel think it is about 8 screws. Once you get the back panel off look closely at the motor. Motor mounts, gears, clutch, brake, and if need be take the bottom apart and look at the main bearing on the bottom of the drum to make sure that hasnt gone bad
Feb 14, 2009 | Kenmore 24032\24036 Top Load Washer
Noise from drum when spinning.
can u move the drum up and down if so the bearings have gone
Feb 03, 2009 | Whirlpool AWM8163 Front Load Washer
Washer makes loud knocking noise
I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. You can also move the inner drum up and down to see if there is something wrong with it..
Sep 28, 2008 | Roper RAS6233KQ Top Load Washer
Washing Machines Logo
257 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
