Question about Hotpoint WMA30 Front Load Washer
Have a funny smell coming from wma 30 removed front panel at front to look for a filter, but no sign. Does this model have a filter, if so where and how do i remove/clean
Try sticking 3 dishwasher tabsn in and put it on the hottest wash should remove smell
Posted on Sep 17, 2010
Our microwave has stopped working for the second time in two years. When you try to heat something, it hums but not quite like it is heating. There is also a funny smell.
SAFTY FIRST
UN -PLUG IT,,,,, THAT "FUNNY SMELL" SOUNDS LIKE IT IS SHORTING OUT
PERHAPS THE MEGATRON HAS GONE BAD, THE MEGATRON IS THE
HEART OF ANY MICROWAVE
AS A EX- FIREMAN, I KNOW FROM FIRST HAND EXPERIENCE THAT
"A FUNNY SMELL " OR " UN-USUALL SMELL COMING FROM AN ELECTRICAL
ITEM IS A SIGN OF DANGER
Feb 05, 2011 | GE Profile Spacemaker JVM1871 Microwave...
Kenmore 90 Series, 10 years old; Dryer was making funny noise and stopped in the middle of a cycle. There was a burnt smell when it stopped. Cannot turn drum manually either. What are possibilities?
OF COURSE SOMETHING BURNT INSIDE THE SYSTEM. YOUR MOTOR MIGHT BE BURNT. 90 SERIES, YOU MUST HAVE THE LINT FILTER ON TOP CORRECT? TAKE FILTER OUT, UNSCREWS THE TWO SCREWS, PULL TOP PANEL TOWARDS YOU AND LIFT UP. DISCONNECT LID SWITCH CONNECTOR, UNSCREW TWO SCREWS HOLDING FRONT PANEL ON, REMOVE FRONT PANEL, TAKE DRUM OUT AND CHECK THE UNIT. GOOD LUCK
TIMOTHY DO 714-334-1998
Aug 04, 2010 | Kenmore Dryers
Why does my front loading washing machine smell bad and make my laundry smell sour?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 19, 2010 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore 'Elite' front loading washer that stinks
Have you been leaving the door cracked open after washing a load? If not, mildew will form and smell. If you have, then it would be something else. Respond with any questions.
Jun 12, 2009 | Kenmore Elite 45986 Front Load Washer
My ge model wbvh5200j2ww washer wont't start. it has power on the panel but doorwon't latch or start filling.
If the pump filter is clogged, the washer won't even turn on. This filter is located behind the small access panel at the bottom on the front of the washer. Remove access panel, flip down scoop, and unscrew filter. You will need a bowl to catch water that comes out(may smell bad). Pull out filter, clean, and replace. Washer should work normally afterwards.
May 01, 2009 | GE Energy Star WCVH6260F Front Load Washer
Where do ilocate the filter on a hotpoint wma 13 washing machine
You will find the filter inside the large black sump hose fastened to the bottom of the tub..
Remove the lower panel at rear of washer, locate hose and remove same ,remove and clean filter inside hose
Refit filter and hose and test.
Plz rate my solution.
Thanks.
Jan 29, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Ice tastes funny and a strange metallic or plastic type smell
Sometimes the smell comes from something in the freezer or even the refrigeratior and makes the ice taste funny. My suggestion is to clean out the freezer compartment of anything frozen that has been there a while and may have freezer burn. That may be the funny smell you are experiencing.
Hope this will help you.
Jan 15, 2009 | KitchenAid KSRS25IL Side by Side...
Mold smell
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Next run your washer with 2 cups of bleach, hot water. After it starts agitating stop the washer & let it remain for 2 hours. Then continue the wash.
Aug 23, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
Hotpoint WMA30 Front Load Washer Logo
95 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
