Question about Nokia 5630 XpressMusic Smartphone
Itel mobile dialer which is installed in my nokia 5630, there is no sound when i dial a number. what are the settings for internet voice call.
3 Suggested Answers
  • 4 Answers
SOURCE: Wrong Voice Mail number programmed into Speed Dial "1" Key
You can not remove it; But you can change it
Follow the steps :-
>Menu
 >Messaging
   >Voice Messages
     >Voice Mailbox NO.(CHange it)
Posted on Nov 08, 2008
  • 30 Answers
SOURCE: Nokia 5630 restarts when attending calls+Voice recorder to memory cards not works
connect ur mobile using data cable and make a full format and then u restart ur mobile.
Posted on Jul 06, 2009
How do I get voicemail of a Samsung s6 phone .
Samsung Galaxy S6: How to get voicemail (phone calls go direct to voicemail)
Hello.. 2 things we need to address here:
1. How to access voice mail account:
Access VM: Press 1:
Easy way to access your voice message system is to go to the dialer pad on your phone and press down on the "1" key until your voice messaging system announces
or you can dial your phone number to get to your voice mail
2. Change Call Setting, go to:
Dialer > (3 dots) Select Settings > Call > (scroll down) Select More Settings > Call Forwarding > Voice Call > then change to Always Forward (turn off)
Feb 14, 2016 | Samsung Galaxy S6 Edge
How to use voice dialer (svoice) with bluetooth on galaxy s5
Corded headsets do not have Bluetooth. Do you have a Bluetooth headset (wireless) handy to test the Bluetooth function properly?
Nov 04, 2014 | Samsung Galaxy S5
Unknown caller and no dial tone problem on voice modem!
'unknown caller when someone calls by using phone dialer' sounds as though the dialler is blocking its identity, which you can prolly do nothing about.
Could rephrase the rest of your Question at least two different way, for clarity, please?
Nov 14, 2017 | Conexant CX11252-11 Modem
How in the world do you set up voice mail on the e71
Hello Debb,
Please visit the link provide below :
http://www.gen-i.co.nz/Solutions/Mobility/Device_Documents/Nokia%20E71/Setting%20up%20Voicemail%20on%20the%20Nokia%20E71.pdf
Apr 15, 2011 | Nokia E71 Smartphone
How to do internet settings manually on nokia e71
BEFORE YOU BEGIN, please note the following:
On the Nokia E71 some of VoIP settings are hidden by default, and you will need Nokia's new VoIP SIP application.
This application can be used to configure VoIP settings on your Nokia. You can create new VoIP profiles and modify the existing ones, and create and modify VoIP parameters and NAT/Firewall traversal settings and that are normally not visible on the device UI, such as codec settings and SIP domain-specific NAT/FW settings. It is also possible to save all the VoIP profile settings to a text file. It also enables VoIP over WCDMA which means you can make VoIP call over 3G Internet connection.
Using your PC you can download free Nokia SIP VoIP application from here or you can check Nokia web sitefor latest version.
Extract and install SIS file using Nokia PC Suite software on your PC.
Once installation is complete you will be able to see "SIP VoIP Settings" application under Applications menu on your Nokia, which you will need in STEP 5 of this configuration guide for better voice quallity or enabling VoIP over 3G Internet connection.
Here you can find Nokia E71 SIP settings for voip setup and SIP client configuration guide with VoIPVoIP service.
STEP 1 Go to Tools / Settings / Connection / SIP settings. Create the following profile
Profile Name: VoIPVoIP Service
Profile: IETF Default
Access point: (your WLAN AP name)
Public user name: 5551231234@sip3.voipvoip.com ( Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. When recorded your phone will show sip:5551231234@sip3.voipvoip.com )
Use Compression: No
Registration: "Always on "
Use Security: No
STEP 2 You do not need to enter Proxy Server settings
Proxy Server Address: none
Registrar Server:none
Realm: none
User Name: none
STEP 3 Enter the following for Registrar Server settings
Registrar Server: sip3.voipvoip.com (When recorded your phone will show sip:sip3.voipvoip.com)
Realm: voipvoip.com
User Name: 5551231234 (Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. )
Password: Enter the password that you chose when you signed up for the service.
Transport Type: UDP
Port: 5060
STEP 4 Go to Tools / Settings / Connection / Internet Tel. Settings
Create a new profile for "voipvoip"(555123xxxx), name it "voipvoip"
Choose "voipvoip" as Preferred profile
STEP 5 For better voice quality or in order to be able to make VoIP calls over 3G internet connection you need to use Nokia SIP VoIP Application you installed.
Go to Applications on your phone and click on "SIP VoIP Settings" application. Choose VoIP services/VoIPVoIP (or the name of your VoIPVoIP account Internet profile.)
Click on "Profile Settings" and find "Allow VoIP over WCDMA" option and change it to "ON" This change allows VoIP over 3G connection on Nokia phones.
For better voice quality go to Codecs and delete all codecs except G729. There should be only G729 codec left under codecs setting
STEP 6 Reboot your phone. Once your phone is back on it will automatically register to VoIPVoIP.
Once it is registered you can start making calls.
Default call type: To switch between normal GSM calls or VOIP calls, navigate to Tools / Settings / Call / Default call type. Select Cellular to make normal calls to the phone number or Internet to use VoIP to call the number or address
Make Calls!
To dial any phone number that is part of the NANP (North American Numbering Plan), you must dial:
1 + Area Code + Phone number
To dial any phone number that is outside of the NANP (North American Numbering Plan), you must dial:
Country Code + City Code + Phone number
For example if you want to call Brazil (country code 55) phone number in Rio de Janeiro (city code 21) you must dial 5521 and phone number. + sign can also be used and number can be dialed as +5521xxxxxxx
BUT RATHER THAN FOLLOWING THESE PLS CALL TO YOUR CUSTOMER CARE THEY WIL GIVE THE SETTINGS. SAVE THEM. THEN FOLLOW THE INSTRUCTIONS. THIS DOES NOT COST ANY COST. PLEASE TRY THIS
Jul 07, 2010 | Nokia E71 Smartphone
My mobile is nokia 5800 music express. so i want to connect internet through my pc
First of all, install the Noki Pc suite on your computer, connect the phone in Nokia Mode, you'll see that your mobile is a Modem, Open the Internet Connection and set your nokia modem as the default modem, create a dial up connection using the Internet Connection wizard, you'll need the number to dial, this number is to be obtained from the Network Operator. Now you can connect to the internet using your phone. Note that the speed will be slow as compared to normal (wired/wireless) internet connection. Good luck Thanks for using FixYa.
Jun 01, 2010 | Nokia 5800 XpressMusic Smartphone
HTC Hero voice dialer does not recognize my
The Hero's voice dialer is a piece of ****. I would not use it at all. It defeats the purpose of voice dialing if you actually have to look at the phone to confirm who you want to dial.
I would see if there is another app that can do voice dialing that is better. I cannot give you any advice on that, since I don't use voice dialing.
Good luck.
Jan 29, 2010 | HTC Hero Smartphone
How to reset a nokia 5630
just reset your factory settings, which is available is setting...or if u want to formae your phone... *#7370# if this code does not work then try, *#7780#
Jan 24, 2010 | Nokia 5630 XpressMusic Smartphone
Jul 06, 2009 | Nokia 5630 XpressMusic Smartphone
I HAVE PC SUITE FOR MY CHINA MOBILE SIGMATEL S9 AND I WISH TO RUN INTERNET ON LAPTOP THROUGH THE MOBILE ,WHAT TO DO?
First of all you should contact your service providers and get the gprs settings and then save the settings
then make a dialler on your system with the phone as the modem or make the phones modem, the modem of the dialer (first of al install the pc suite)
then according to your regional you have to choose the number to dial (for this too you can contact your service provider)
May 18, 2009 | Smith Micro QuickLink Mobile for Pocket PC...
Nokia 5630 XpressMusic Smartphone Logo
52 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
