Question about Disney High School Musical DVD Player
I activated the parental control on the dvd player..and I don't remember the password..because a lot of movies won't play such as bring it on..superstar etc..how do I go about retreiving the password
    Problem Solver:
  • 5 Answers
Try using the original password that goes with it.
Posted on Sep 17, 2010
I have a Toshiba SD-K730 DVD Player I am trying to set the Parental Lock limit what type of movies are viewed. Can you help?
Parental control setting
Some discs are specified not suitable for children. Such
discs can be limited not to play back with the unit.
1) Press C or D to select "Parental", then press B
or A until the level you require appears.
Level Off: The parental control setting does not
function.
Level 8: All DVD software can be played back.
Level 1: DVD software for adults cannot be
played back.
Select from the level 1 to level 8. The limitation will
be more severe as the level number is lower.
2) Press C or D to select "Password".
Press Number buttons (0-9) to input a 4-digit
password. Be sure to remember this number!
• If you input a wrong number, press CLEAR.
3) Press ENTER to store the password.
Note: Now the rating is locked and the setting cannot
be changed unless you enter the correct pass
word.
4) Press OPEN/CLOSE to activate Parental control
setting. (See "Temporary disabling of rating level by
DVD disc" on page 36.)
Notes:
• Depending on the discs, the unit cannot limit playback.
• Some discs may not be encoded with specific rating
level information though its disc jacket says "adult." For
those discs, the age restriction will not work.
To change the parental level
1) Press C or D to select "Password".
2) Press Number buttons (0-9) to enter the password
you have stored.
3) Press ENTER.
• The rating is now unlocked.
4) Press C or D to select "Parental", then press B
or A to change the parental level.
5) Press C or D to select "Password", then press
Number buttons (0-9) to enter the password.
Note: You can change the password if you want.
6) Press ENTER.
Now the parental level is changed and locked.
If you forget the password...
1. Press OPEN/CLOSE to open the disc tray.
2. Remove the disc.
3. Press OPEN/CLOSE again to close the disc tray.
"No Disc" appears on the screen.
4. While holding STOP down on the front panel,
press 7 on the remote control. "PASSWORD
CLEAR" appears on the screen.
5. Enter a new password again.
hope this helps
John
Mar 24, 2011 | Toshiba SD-K740 DVD Player
Purchased the pink Disney Princess DVD player from KMart. When you turn it on and insert a DVD to play, screen comes up saying the Parental Controls have been set (Universal Studios picture in upper left...
lots of electrical items will use a default security code of 0000 or 1234.
if there is nothing in the manual and these codes do not work, then your best option would be to return it to the store for them to find the codes or refund/refpace the item
Feb 28, 2011 | Disney Princess MCP DVD2050P DVD Player
Need to reset code
Found this on another site, from personal experience but its very well written so here you go.
The Playstation 2 is not only a video game system, but also a DVD player as well. In many families, the Playstation 2 serves as the "kids" DVD player, which means that many parents choose to take advantage of the parental lock feature to limit what kinds of movies the Playstation 2 will play back.
There could be instances where you entered in a parental code months ago, and now can't remember it. Or, you may have purchased a used Playstation 2, and you never knew the code to begin with. If you or the prior owner set a parental lock code, the Playstation 2 won't play back many movies without entering the code first. You could try to hunt down the original owners, or start inputting every code possible starting with 0000, but it's easier to reset the password and disable parental lock using a secret code.
Here is the procedure to reset the parental lock code:
  1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
  2. When the screen asks for the code, press the SELECT button, then enter in the code "7444".
  3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
  4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
A note for parents: If you're wondering what is stopping your child from using the above procedure to circumvent your rules, you can verify that they haven't reset the parental control very easily. Since the above procedure eliminates the old password entirely, all you need to do is see if your original password still works. If it does, they did not use the above procedure to break the rules. If it doesn't, they might be trying to pull the wool over your eyes.
Please rate accordingly
Justin
Jul 28, 2010 | Sony PlayStation 2 (PS2) Console
How can I change the parental control? Somehow the parental controls are set on the DVD player and it will not allow me to play certain dvds without a password
Unfortunately there are no known ways to change the user code. The parental controls are set because it's a DVD player for kids - and you must input the password every time you want to play a DVD.
1369 is the code to allow you to play blocked movies. I still haven't found a way to change the level. Again, you have to input the code each time. I know it stinks, but I guess they didn't think of the parental feature in its entirety.
Jun 24, 2010 | Disney Ramone DVD Player
There are some dvd movies that when I try to play them it ask for a password how do I get one to play the movies
Sound like parental control is set based on the rating of the movie. Ask whoever set the
control.
Dec 29, 2009 | Televison & Video
Parental lock
the preset password is 3308. but first goto set up menu select rating press enter/play, select rating agin press enter/play, chose rating you want, then enter password 3308, press set-up to exit, press enter/play to start.
Apr 27, 2009 | KLH KD1220 DVD Player
Parental screen coming up on a DVD. Not able to watch DVD.
use password 3308 to change the parental control to 7, and the movie will run
Feb 14, 2008 | GoVideo DV2150 DVD Player/VCR
Dvd troubles
Same problems with my unit.  But, try this... I think it worked.  First, you can not get to the setup screen for the unit with a DVD in the player.  So, remove the DVD first:  Unplug the unit, wait a few seconds, plug it back in.  Then hit the DVD open button and remove DVD in player.
I think the issue with not reading certain DVDs is a problem with the "parental control" on the unit. Without setting parental control there were a few DVDs I could not play and sometimes (not always) I was asked about parental control before a movie would play.  At the Sony Blue DVD screen, select Setup on the remote control.  Select DVD setup and get to Parental control.  Set a password.  This will then take you to a "rating" screen.  By setting the rating very high (I set mine for #8) any movie should play without needing the password.  With no password set, you can not change the "rating" and hence mine was set at #1 (kids).  It seems to have worked for now anyway.  Good luck.
Oct 14, 2007 | Sony SLV-D300P DVD Player/VCR
How do you reset the parental control code?
Called Zenith.  They said: turn on the DVD player.  Hit "set-up". Scroll down to the "lock" icon.  Scroll over to "Rating". Scroll over to unlock.  Enter 0000.  Click on Ok.  Enter 0000 again, click Ok again.  Menu should read unlock.  Voila!
Aug 24, 2007 | Zenith DVB412 DVD Player
Parental Controls feature
Hey Aurora, After you put your password in, go back and change the password using blanks spaces. Then it should reset to 'parental control off'. Let me know if this works. Some Sanyo models are different to reset.
Jul 21, 2007 | Sanyo Vizon LCD-15A2 Television
Disney High School Musical DVD Player Logo
126 people viewed this question
Top Disney Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Rick
Are you a Disney Audio Player and Recorder Expert? Answer questions, earn points and help others
