Question about Maytag Washing Machines
Water runs right through when I want it to fill tub on Maytag topload.
  • Maytag Master
  • 909 Answers
Simply, your drain pipe is much to low. You need to raise it a little higher than the actual tub.(Its to stop the siphoning effect.). Retry and presto, all is well.
Posted on Sep 17, 2010
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 26, 2011 | Maytag Washing Machines
My maytag topload washer overfilled,
It isn't a sensor problem, it sounds more like your water level tube has pulled loose. This is attached to the outer drum itself. You can see it when you remove your front cover to the right of the outer tub. This tube uses the pressure generated from your tub water level to push air up to your water level selector, which has a rubber membrane that flexes and closes 2 contacts as the water level makes the rubber expand. If that tube is off, the water will just keep running.
Mar 18, 2010 | Maytag MAV3905EWW 13 Cycle Washer
Maytag washer
Many of the maytag toploaders have a rubber fill hose at the top of the outer drum.
Sometimes if the machine is fully loaded (or overloaded), during the spin cycle if clothes are above the top of the drum they can actually knock the rubber flange of the hose out of the drum. Then when the machine fills with water, it will dump it down the outside of the tub and it will appear that the water is leaking from the top and side of the drum... Fix it by snapping the fill hose flange back into the hole in the top part of the drum... let me know how you do or need more help...
Mar 23, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag legacy series tub wont fill
Your drain hose is too low or there is no air gap where the hose enters the drain line.
This causes the water to siphon out as it fills.
Mar 08, 2009 | Maytag Legacy Series Top Load Washer
Model mav6000awu has a sound of water rushing when machine finished filling and running.started doing this recently.
most maytag toploader mav did have that sound if it drain & spin your ok i have the same washer and it has the same sound & work fine that washer will only last about 10 years (i work for maytag )
Feb 18, 2009 | Maytag Washing Machines
Washer won't fill
First take off the fill hoses from the washer, make sure the screens on the washer valve are not clogged. Next heck nd make sure you have water coming from the hoses. Finally if still no water. you may ned a new fill valve. Hope this helps , Dave www.washermd.com
Dec 22, 2008 | Maytag HAV3460AWW Top Load Washer
Maytag topload washing machine
either you have a bad pressure switch or the latex hose to it or has a hole in it it may have come off either the tub or the switch if it was shaking badly it will be connected to the fill option switch on the control panel go down then hook to tub
Dec 30, 2007 | Washing Machines
Maytag Neptune TL.
easy!the water pressure switch is not working the little hose going to it could blocked or off,or the pressure switch bottle could be blocked. rate me if right Eire
Dec 02, 2007 | Maytag Neptune MAH5500B Front Load Washer
LAT9235AAE
Put the tube back on switch and remove other end from tub. Then blow and see if switch is working
Sep 23, 2017 | Maytag 22 Cycles Topload washer, SAV365Z
Washing Machines Logo
48 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
