Question about Plumbing
We had a power outage last night and when the power returned we realized we had no water pressure. the pressure tank will not come on and the pressure gauge is at zero. is ther a reset switch or somthing? i flipped the breaker and checked the wiring nothing seems burnt. It is about 10 yrs old. Thanx
    Master:
    Sergeant:
  • 449 Answers
You should have a pressure swich on the pump a grey box with a switch on the side pull the switch up
Posted on Sep 17, 2010
Davey pump loosing pressure from rain water tank to house but seems to be fine through the day but loosing pressure at night?
replace the pressure control switch as the problem indicates the non-return valve is leaking back and not holding pressure
Dec 10, 2016 | Plumbing
Rheem Power Vent 50 gas water heater will not come out of vacation mode! Have tried turning on and off, resetting and following directions on the side of the tank. Will not come out of Vacation Mode. Had a...
Water inside tank-type water heater can remain hot for some time.
That's one advantage of well-insulated tank-type water heaters.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Power outage can be related to failure of gas control.
Unplug stuff when power goes out. And then plug back in after power is restored.
Water heaters with electronics are not protected from surge.
Electronics can blow out during and after power outage. For example nearby lightning strike will cause current to run along household wires. With ordinary power outage, once power is restored, the surge can affect all kinds of electronic circuitry such as timers, water heaters, water softener, treadmill etc.
Sounds like you have intellivent gas control valve:
Open following link to identify gas control, and download typical manual, and download intellivent service manual with troubleshooting, error codes, etc.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 26, 2011 | RHEEM 50 Gallon FVR NATGAS Water Heater...
Power outage last night and now water heater doesnt work? thanks
You posted under tank-type electric water heater.
1) Check the circuit breaker.
2) Open top cover located on side of tank and push in reset button.
3) If these two actions do not restore function, then open following link for complete troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Jul 24, 2011 | Reliance & 50gal Electric Water Heater
The pressure tank psi may be too high. To set it you get the system to pressure up and stop then check that water pressure. Whatever that is, is what the tank should be set at. Too much air pressure and the water pressure will suddenly drop before the pump kicks in.
To set the tank properly turn off the pump, drain all water pressure, then set the air pressure in the tank to the same as the water pressure was. Turn it back on and check again.
Apr 14, 2017 | Water Heaters
Thermador Oven E10 error message--due to power outage?
HI. During the power outage, there may have been a power surge. This has shorted your main control board. This E-10 is indicating that this is the issue. This code represents a failed control board. It must be replaced, in this case. Once replaced, the unit will return to its normal operating status.
Dec 08, 2009 | Ovens
My whirlpool duet washer displays an "F 74" error code. We had a power outage, the washer is plugged into a surge protector. I called whirlpool last night - they had me unplug for around 10 minutes, plug...
F74 is not a valid fault code. If it was F14, then it was bad eeprom value (on timer board).
Try tripping circuit breaker or unplugging the power cord. Connect power back and follow reset procedure again, that will reset NVRam.
Ensure that there is no water inside the machine. If there is water, while machine is disconnected, empty water.
If that does not work, the control board may be defective.
Oct 09, 2009 | Washing Machines
Power outage, now pc will not power up at all
OK FIRST A POWER SURGE PROTECTOR WILL ONLY PROTECT YOU 7 % OF THE TIME, WHICH YOU JUST REALIZED. SO YOU NEED TO BUY A BATTERY BACKUP ALSO KNOWN AS A UPS.... I CANNOT STRESS THIS ENOUGH. BRING YOUR PC TO BEST BUY AND THEY WILL TEST YOUR POWER SUPPLY, IF IT TESTS OUT OK THEN YOU BLEW SOMETHING IN YOUR MOTHERBOARD. GET A BATTERY BACKUPS/UPS!!!!!!!!!!!!!!!
Jun 12, 2008 | HP Media Center m7060n PC Desktop
Power outage last night. Deleted all saved voicemail messages. when turned on - machine says "no massages" How do I retrieve lost messages?
I'm sorry there isn't. Answering machines like this have very little ROM memory. After a powersurge and outage like last night, it wiped the whole memory chip. You can try there support page. It's actually pretty good. http://telephones.att.com/telephones_ui/support/index.cfm
Jun 28, 2007 | Lucent 1872 Corded Phone
Plumbing Logo
123 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
