Question about Dell UltraSharp 1707FP 17" LCD Monitor
I have a Green vertical line on my dell1707fp LCD when I turn on it. which is always at the same place every time I start pc.some times this line vanishes and everything becomes fine and good. what's problem?
2 Suggested Answers
oldrogers
  • 53 Answers
SOURCE: 1/8 inch wide vertical streak on dell lcd monitor grey-green
There are loosed contacts between scaler board and flex-cables, at least those where you have color lines. These cables are glued with anisotropic compound and not such easy to fix, to make it right you shall heat junctions to certain temperature and press the cable down to surface with certain pressure, which is specified for compound used in there - consider as unknown.
The easiest way to get rid of these lines is to press flex-cables with something like piece of foam rubber.
Disconnect all cables coming from the display to boards, take the chassis off, unscrew metal cover from back side of display to get access to the scaler. Now, if you can, connect display back to boards (you may need to take boards off the chassis) and turn on the monitor. This will help you to find exactly loosed spot. Gently pressing to junctions of flex-cable to scaler PCB with finger observe the behavior of color lines on the display. Then put there thin piece of foam and fix with metal cover. That will work for awhile.
Posted on Sep 13, 2009
Vertical red lines no matter what input.
I'm assuming you're dealing with an LCD flat panel monitor.
If you've tried different input and from different computers and different cables, and you're still seeing vertical red lines, it's highly likely that the LCD is failing and there's not much that can be done easily to fix it. You will probably need to replace the LCD panel.
If the red lines are in different locations each time you power on, then it could be a controller board issue. But, if the lines are always in the same place, it's probably the LCD panel itself.
Oct 22, 2016 | Computers & Internet
How to fix green vertical line on 60" vizio led smart tv
I had a similiar problem on a Sony , vertical line or lines on the left side of the screen. It was the driver board for the LCD. Good Luck
Mar 17, 2014 | Televison & Video
Vertical green line screen try
Have you tried to do a reset via the monitors menu options?
Jan 21, 2014 | HP w1907 LCD Monitor
LCD display problem
Are you sure the cable is properly seated? You will typically get a tint of red green or blue when a particular pin on the cable isn't making contact. The lines on the other hand would indicate a bad display. Best advice would be to check the cable and if its all the way in hen replace the monitor. They are not worth repairing and also dangerous to work on.
Nov 24, 2013 | Sharp LC 37A63M 37" LCD Flat Multisystem...
Vizio LCD problems: LCD control board or LCD panel?
I think you are looking at a defective LCD panel. But the set will need to be properly diagnosed to tell for sure.
Sep 04, 2012 | Vizio VW46LFHDTV10A 46 in. LCD TV
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Single Blue vertical line appeared on the sanyo 42'' LCD screen
vertical ic fult or vertical section supplys missing
Jun 12, 2009 | Sanyo Televison & Video
Vertical green lines
It sounds like th green LCD panel laminations or bonding has separated and this is causing your green lines. The optical block would have to be replaced to solve the problem.
Oct 07, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Vertical lines in lcd
sounds like your graphic card is bad, try first to download updated drivers from the internet and see what happens, also try to connect an external monitor and see what happens.
Mar 02, 2008 | IBM ThinPad R51 (2887EXU) PC Notebook
Laptop lcd screen
that's not a firmware issue..your lcd is starting a slow decay to final unhappiness..
you can try the old driver downloader trick, but it's just a matter of time now.
Feb 21, 2008 | LG Flatron L1750S 17" LCD Monitor
Dell UltraSharp 1707FP 17" LCD Monitor Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
