Question about SanDisk Sansa Fuze MP3 Player
When I plug in my player it does not charge the battery. The screen stays on and it shows that it is connected. This morning I plugged it in and the screen shows it is writing? It is still ot charging Tom
  • 3 Answers
I used to have one....you just need to turn it off when its charging.
Posted on Sep 17, 2010
I can't turn my olympus digital voice recorder WS-450S on, even with a new battery, i hadn't used it in a while, so i was shocked that it didn't work. It only turns on if i plug it in to the computer, but...
I've got this same problem :( Turns on when I plug it in to the USB, stays on when I disconnect it but if I turn it off I can't turn it back on again. It is showing a "battery low" warning and I tried to charge it via the USB last night, but it seems to stop charging after a while and despite being left for a good time last night, this morning it is the same and I've had another battery low warning.
I've just found the full pdf manual online, and have found (on page 80) a reference to it not always behaving stably when connected via a USB hub. I'm going to try to charge it via a direct port and see if that fixes it.
Oct 17, 2010 | Olympus WS-100 Digital Voice Recorder
Not sure if player is charging
QUESTION ONE:
Can you see it in "My Computer"? It will show under "Removable Drive/Storage"
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and movie folders?
QUESTION THREE:
Can you see the player in Coby Manager - under the "DEVICE" tab?
QUESTION FOUR:
When disconnected from the computer, how long can you listen to the Coby player before it goes off?
If not present in My Computer or in Coby Manager/Device Tab, then it is not plugged in correctly.
a. Disconnect the player from the computer.
b. Wait for it to cycle through "Please Wait" and "Updating Library" screens.
c. Make sure the player is TURNED OFF
d. With player TURNED OFF, reconnect wire to the player then to the computer.
e. You will see a USB connector icon on the player screen and the player charging.
It will appear to be charging all the while it is connected to the computer.
After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8 hour charge - with the coby player OFF - through the computer. (This one got me when I first got my player!)
f. Use the Coby Manager to disconnect the player (Found HERE CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
1. Open Coby Manager
2. Go to the DEVICE TAB
3. CLICK on EJECT Button in lower right hand corner.
4. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
5. The second pop-up screen will tell you "The device can now be safely removed from the system."
6. Disconnect the player from the computer.
7. The Coby will now show "Please Wait..."
8. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
You should now have enough battery power to use it. To check the battery level,
1. Turn on the player
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter as the battery is wearing down.
Hope this helps.
Apr 07, 2010 | Coby MP-610 MP3 Player
Battery level shows about half. Charging arrow doesn't show.
Try a different usb cable or mabey the actual usb port
Jul 09, 2009 | SanDisk Sansa e250 MP3 Player
Freezes on 'Samsung' screen
While the unit is connected to the PC, hold down the RESET hole at the back for 10 seconds.
Mar 23, 2009 | Samsung YP-Z5FA MP3 Player
The player won't turn on.
Hey illinifansx5,
Have you tried plugging in the unit to your PC and then pressing the reset button for 5 seconds?
Also, try removing the battery for 30 seconds, then replace and attempt to charge.
If these options don't work, it may be a hardware or battery failure and you should try to return it.
May 19, 2008 | Insignia NS-DV2G MP3 Player
Philips mp3 player sa6045
This player shows the "Do not disconnect" message when it is doing something critical such as transferring tracks or updating firmware, which could corrupt the player if disconnected part way through.
The player shows the "OK to disconnect" when it is idle. As the message says, it's ok to disconnect, as the player will not corrupt if disconnected when it is idle.
These messages mean that the player does not need the "Safe to remove" procedure.
It is ok to disconnect part way through charging. Also the player will condition the battery once it is fully charged, so it's ok to leave it charging.
Occassionally batteries can "memorise" when constantly disconnect and reconnected without fully charging and discharging. To help prevent this, fully discharge the player (leave on until dead) and fully charge and condition (leave charging for about 12 hours) every couple of weeks or so.
Feb 11, 2008 | Philips GOGEAR SA6045 MP3 Player
RCA Pearl TH1101A MP3 player not charging battery
the rca pearl does not have an external power source, only the AAA battery. Just put in a new AAA and you're good.
Feb 08, 2008 | Audio Players & Recorders
I have a GoGear device that won't charge
Hi, I had the same problem with my SA31xx, when I plugged it into my PC it made the normal usb sounds and then a flash symbol appeared over the battery on the screen. It would not charge at all, I replaced the usb cable and it now works perfectly. Hope this helps.
Oct 03, 2007 | Philips GOGEAR SA6045 MP3 Player
SanDisk Sansa Fuze MP3 Player Logo
147 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
