This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
There is a button on the bottom right sidewhich says "end of cycle". On my machine it says hold button for 3 seconds to lock/unlock controls. I hope this helps because I remember losing it when my out of warranty machine stop responding. Good luck.
CONTROL LOCKED
This feature allows you to lock your settings to
prevent unintended use of the dryer. You can
also use this feature to prevent unintended
cycle changes during dryer operation.
To enable the Control Locked feature:
Press and hold the End Of Cycle Signal button
for 3 seconds. The control is locked when a
single beep is heard and the Control Locked
status light is on.
• When the dryer is off, it is not necessary to
press the Control On button before activating
the Control Locked feature.
To unlock the Control Locked feature:
for 3 seconds to turn this feature off.
NOTE: When the dryer is running and Control
Locked is on, the dryer can be stopped by
pressing the Pause/Cancel button, but cannot
be restarted until the control is unlocked
Let me know if this does not work.
Kelly
