Question about Coleman Mosquito Deleto Octenol Refill 2960-601
MY 6 YR COLEMAN MESQUITO DELEETO WILL NO LONGER START UP. NEWER BATTERIES CKD OUT OK...NEW PROPANE...SOUNDS LIKE IT WANTS TO START...UNLESS IT'S SIMPLE 2 FIX...I'LL TOSS IT....NOT HANDY AT ALL....E
There is a brass fitting between the two hoses that connect to the two together, the pin hole in the fitting is probable plug and the gas cannot get in. I soak mine in vinegar and use a straight pin to clean it. Then hold it up to the light and see if you can see the light through it
Posted on Mar 23, 2012
Engine starting on full boost
If its starting w a boost that means your battery isnt doing its job. The connections on the battery may be the troublemakers too.1st, get the batt & alternator ckd & ckd for electrical shorts. If all is well it could be the starter itself. Start at the basics, batteries always are step 1 in this case. get it ckd & go fm there. Sounds like an easy one. Good luck
Jun 13, 2016 | Cars & Trucks
Coleman propane furnace pilot light goes out
Check propane pressure, also check for water or other contamiants in the propane.
Nov 13, 2013 | Heating & Cooling
Have three coleman hws same problem on last weekend. Fully charged batteries 6.45volts. New gas bottles. Turn unit on water starts to run gas ignites for one to two seconds and then goes out water will...
It will probably be one of two issues. Either the waterflow sensor is not working correctly or the propane valve connected to to control knob is stuck shut. The water flow sensor is located on the side of the copper element (grey box) check that it spins easily. The propane valve is attached to the control knob by a long metal wire and should turn freely as you turn the control knob to warm
Jun 21, 2010 | Coleman Hot Water On Demand
How to fit a mantel to a coleman propane lantern
Hi, First remove the knurl nut on the top. Remove the top and then the glass globe. There are several types of mantels most of which tie with a string that is part of the mantel top. The newer ones have a wire clip in place of the string. Which ever type you had on before you need to remove the old pieces completely. Since the mantles burn to an ash they will disintegrate when touched but if it had the metal clip you need to remove it. Tie or clip the new mantle over the lip on the output orifice being careful with the screen underneath. Replace the glass globe and top, put the nut back on finger tight. Remember that the mantel turns into ash when it burns for the first time so keep the gas low to start it till the mantle forms properly ( in the first minute) Good Luck, this should Fixya!
Mar 16, 2009 | Coleman Camping, Backpacking & Hiking
I have a 15 year old Coleman Propane 130,000 Btu force air furnace, Model #BGU13020 forced air furnace. Afer the unit runs for 5 to 10 minuets, the flame will start to shuter and then it will trip the heat...
DO NOT attempt to repair this yourself. LP gas is a very unforgiving gas. Sounds like your heat exchanger is plugged. Yes it can be removed and checked, BUT it is not recommended. Trust your local repair tech. Any heater 15+ years old should be discarded.
Dec 26, 2008 | Coleman Propane Forced Air Heater...
Propane-converted generator sometimes sputters out and dies
I believe the problem may be with the propane. Have him call his propane provider and get them involved. good luck
Dec 26, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Mosquito Deleto Octenol Refill 2960-601 Logo
105 people viewed this question
Top Coleman Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coleman Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
