Question about LG LWHD1800R Wall/Window Air Conditioner
LG LWHD1800R air conditioner problem
I live in Sacramento, CA. I have an LG LWHD1800R window type air conditioner. It is mounted on the second floor with unobstructed south west exposure (there are no other window locations in which to mount it). We experience several days of triple digit weather here. The AC unit is three years old. My problem is that the unit does not sufficiently cool my living space. The compressor will only kick on for brief periods of time (15 - 45 seconds) at 30 to 45 minute intervals. When the compressor runs the unit does blow cold air; it simply does not run nearly enough to achieve any nearly significant cooling effect. When first installed the unit was a much more efficient cooler. The cooling capacity of the unit seems to have degraded steadily over time (i.e. continuously as opposed to a jump function), and, the way I recollect, it has been a function of decreased compressor activity. I've tried moving the thermistor around, away from the evaporator assembly, and even hanging it outside the unit to no effect. I keep the filter in front of the evaporator clean. I would assume that the compressor motor would have some kind of thermal protection. Could this switch degrade over time? Could the environment (2nd story, south west exposure, 105 degrees F) simply be too harsh for the unit? I'm particularly curious to find a solution that would explain a gradual degradation in cooling capacity; again, for the brief periods that the compressor actually runs, the unit does discharge marvelously cold air. Any help that you may give on this problem would be greatly appreciated.
Heated in Sacramento
    Novelist:
    Champion:
  • 230 Answers
It sounds to me like the compressor is overheating and tripping on internal or external overloads. After the unit cools down again it will try to run for a little while. Then this cycle would start over. I would check the condenser coil for dirt and filth. This portion of the unit may be on the out and backside of the unit. You should at least be able to see light through the coil.
I believe the thermistor that you removed temporarily is used for a freeze situation. I do not believe that it is your problem. Good luck:)
Posted on Jun 18, 2008
5 year warranty. Call LG
Posted on Jul 01, 2008
When I try to turn on my LG wall mount unit it will not turn on
Does it give you a code? Try turning only one at a time to see if that works. I would like to help you but need more information.
Sep 18, 2014 | LG LWHD1800R Wall/Window Air Conditioner
Air conditioner repair
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. Air Conditioner Fort Lauderdale
May 25, 2014 | LG LWHD1800R Wall/Window Air Conditioner
Lg air conditioner t-stat temp sensing bulb
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.Air Conditioning Coral Springs
Ice on inside coil
Thaw it out and clean the filter and coil if you can and if it still freezes up it is low on refrigerant. If thats the case then replace the whole unit, you can't service the refrigerant circuit on windows units anymore.
Jun 16, 2011 | LG LWHD1800R Wall/Window Air Conditioner
Can unit be installed with only the back coils exposed to outside?
Yes.
You want to install the unit where the back (condenser) coils 'are' exposed to the outside.
Jun 09, 2010 | LG LWHD1800R Wall/Window Air Conditioner
Receptacle. the box says 208/230 volts ac 15 amps
Buy a NEMA 15-R recaptacle at an electrical supply house.
Jan 27, 2010 | LG LWHD1800R Wall/Window Air Conditioner
I have a lot of water splashing out on the left side of my LG LWHD1800R, and am not seeing any drain from the drain pipe. How can I stop so much water splash from the side vent?
There isn't a drain persay the drain is the holes under the a/c in the window sleeve. There could be a blockage in the drain pain on the a/c itself. This is the pan the coil at the front of the a/c issitting in. The best way to clean this is to remover the unit from the wall sleeve and take it where you can rinse the bottom of the a/c out make sure to clean the area where the coil sits. Do not wet the entire unit only the area where the steyrene at the base of the coil. Also it the wall sleeve is a complete wrap around make sure you clean it also.
Good luck on your repairs
Dave
Dec 03, 2009 | LG LWHD1800R Wall/Window Air Conditioner
GFI on cord trips out.
Probable cause is a single pole gfi opposed to a double pole gfi.
* Do not use a single pole GFCI ON A MULTI WIRE CIRCUIT, IT WILL NUISANCE TRIP IMMEDIATELY
Use a two pole GFCI circuit breaker on such circuits.
May 20, 2009 | LG LWHD1800R Wall/Window Air Conditioner
Central air
Most thermostats have a setting for the fan called, "manual". That keeps the fan on continuously. The electronic thermostats can fail in a "fan on" condition. That would require a new thermostat. I also saw one air conditioner with a fan relay welded "on" by electrical surge. That would require a new relay.
Jul 20, 2008 | LG LWHD1800R Wall/Window Air Conditioner
AC WILL NOT SHUT OFF
SOUNDS LIKE THE T-STAT TEMPERATURE SENSING BULB IS OUT OF "AIR-FLOW" (SOME CAN COME LOOSE FROM THEIR MOUNTING CLIPS) OR IT IS BAD ALL TOGETHER ... MOST MANUFACTURERS HAVE A ONE-YEAR WARRANTY ON SMALL PARTS AND 5 YEARS ON THE COMPRESSOR .., HOPE IT HELPED.
Mar 27, 2007 | LG LWHD1800R Wall/Window Air Conditioner
Heating & Cooling Logo
361 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
