WF-908 AIR COOLER/HUMIDIFIER manual - Heating & Cooling
Unistar DF - 268A air cooler/humidifier/ionizer
I would like to help you but you need to post exactly what the problem is. There is no information about what the problem is.
Jun 20, 2014 | Heating & Cooling
Information needed: Celsius WF-604 Air Cooler - Their are 2 Push Button Switches on the cooler the: The Cool Push Button Switch and the Swing Push Button Switch. This creates a total of 4 sets of...
The on/off COOL switch controls the moving pad (on rollers), when ON the pad rollers rotate and pull the pads around in a circle. Pad picks up water at the bottom and evaporates water at it rises, thus it is an evaporation cooler.
The on/off SWING switch controls the oscillating louvers which can be stationary or moving left and right. It directs the air flow from straight ahead to the sides.
Either can be on or off.
The Speed controls switch, which you did not mention, determines how fast the fan blades will spin.
Aug 21, 2011 | Heating & Cooling
Is it possible to use the airconditioning and dehumidify at the same time?
yes of course ,the airconditioning actually condiontions the air just like a humidifier,as though a humidifier takes moistures out of the air.an the a/c supplies the cooler dry air ...so your answer is yes it okay to run both systems.
May 13, 2010 | Danby DPAC8399 Air Conditioner
Our house is extremely humid and the a/c needs to be set lower to feel cooler. What are we doing wrong regarding aprilaire humidifier on our furnaces? Shouldn't they be turned off? yet the directions...
Hello
It depends on personal preferance,an air conditionner is going to remove humidity or water from the home,as water contains heat.
I would shut off the humidifier.The 40% setting depends on where in the world your located,say nevada is dry and hot so you may want a humidifier.Where florida is hot and humid so you would want to dehumidify or get rid of the humidity.
Lower the setting to 20% or just turn it off.
May 03, 2010 | Aprilaire 600 Humidifier
No matter what setting is put on furnace humidifier, moisture forms on windows.House is only 6 years old and does have a lot of windows.
Hello WPwilkers, Well there's good news and good news!
First off, you should probably use the lowest possible setting as your house being so new, is likely pretty "air-tight" and as such, doesn't have a lot of air infiltration (gaps and drafts) hence the reason you're seeing moisture on the windows.
Now, I would also use a hygrometer, just like your parents likely had hanging on a wall somewhere in their house. It will give you a better idea of the moistur (humidity) around the house. My guess is that you're already at the 60%+ level of humidity.
I suggest that you turn "OFF" the furnace mounted humidifier, until you no longer see moisture on the windows. That will allow the house to adjust and get back to normal humidity levels.
Then you can start by setting the humidifier on the lowest possible setting and keep an eye on the moisture levels in your coldest room of the house, as that is where you'll first notice the excessive moisture on the windows (just the way it works - cold rooms get condensation on the cooler windows first).
If you don't have the humistat (the control for the furnance mounted humidifer) mounted next to your heating and cooling system thermostat, you should do that - it will make it easier to adjust and also will provide a more accurate reading for the humifier to operate properly.
Some Thermostats have the ability to add a humidifier on it for integrated controlling of the furnace humidifer. Check your Thermostat and Furnance owner's manual for details.
I used to have the same problem and found that by moving the humidifer control from the utility room (mine was in the basement of my house) to the living space, it made a big difference. Since most people's homes have unfinished basements and that's where the HVAC system is located, it doesn't get the same humidty readings as an occupied living space.
The other reason that you tend to get moisture (condensation) forming on windows is that the Percentage of humiditfication is set manually with the humidifier control, and yet, the outside (and inside) air temperature vary and the difference between them can cause the humidity levels to go from very dry to very moist, in a day or two.
I tend to wait until I notice that the air inside the house is getting dry and then turn on my humidifier, once the cold winter days have taken hold. In summary, nothing wrong with your unit, just mother nature and a well built (most air-tight) home are giving you higher levels of condensation than most older homes. Gradual adjustments, once you turn the humidifier off for awhile, should get you the desired results.
I hope you find this Very Helpful and best regards!
Dec 17, 2009 | Honeywell HE365 Humidifier
Where would I find a replacement remote for the Maytag M6Q10F2A air conditioner in southern ontario,Canada Darren
WE HAVE THEM IN STK 19.99 PLUS SHIPPING.
ALL BRANDS APPLIANCE REPAIR
813-908-2002. TAMPA F
allbrandsappliancerepair.com
Sep 23, 2009 | Maytag M6Q10F2A Air Conditioner
I NEED TO KNOW WHAT PERCENTAGE MEANS ON A DE-HUMIDIFIER
In plain English, the Percentage setting on your de-humidifier is the percentage of moisture that you want to maintain in the air. Relative humidity level range from about 10% (VERY dry air) to almost 100% (VERY damp air). When relative humidity is 100%, water vapor in the air will turn into rain, condensation, dew, snow or frost. 50% humidity is usually a comfortable level, but that will also depend on air temperature. The more moisture there is in the air, the warmer it feels and conversely. Warm air will hold more moisture than cooler air.
Your body is cooled when moisture on your skin evaporates into the air, carrying body heat with it. As the humidity in the air rises, less of your body moisture is able to evaporate and thus your body feels wamer. Lower humidty allows moisture from your body to evaporate more quickly and you feel cooler, both at the exact same temperature.
Jun 28, 2009 | Kenmore 54701 Dehumidifier
Air coming out of an adobeair portable evap cooler isnt cold
paula298,
A new unit will take a while for the pad to become wet and more efficient. Remember, there may be two switches: fan and water pump. The unit must be full of water and the pump ON to work correctly.
If the unit has a water pump only setting, run the pump without the fan for about 20 minutes. That will get the pads nice and wet and you should get a good result. A rule of thumb in the desert is 20 to 25 degrees of cooling compared to the ambient air.
Don't use a cooler in closed area. The cooler will simply act like a room humidifier. Use in an open garage or porch for the best result.
I hope that helps.
Ed Phillips ed@azalmanac.com
May 12, 2009 | AdobeAir Evaporative Cooler Direct Drive
Blueway airconditioner/heater/humidifier
I purchased a Blueway Mod BL 168 cooler N12907 0041344 air cooler/humidifier today November 9th, Purchesed from Rezzies Betta Electrical Stocklands Mall 5 Breeze Parade Forster N.S.W
My son was the sales Person, he was very busy so we took the display model which was last one in stock, he was very6 busy and could not find the book for it, They all looked later and still could find the book, I need this before I can use it. Cant get Blueway Company up on the internet. Please help me out here, as its very hot and I cand use it Thank You so much
Heather Kirkby
Jun 14, 2008 | Humidifiers
Fujitronic FH-776 air cooler
I have looked all around sir, Cant seem to find one.
Aug 03, 2007 | Fujitronic FH-776 2.11 Gallon Humidifier
Heating & Cooling Logo
108 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
