Question about Dell 1503FP 15" LCD Monitor
My monitor does not work.
My dell flat panel monitor led lights go on but the monitor has no picture, please advise. one led is green and the other yellowish. i have a 1503 fp purchased in 2002.
  • Anonymous Jun 01, 2008
    i have pluged all the cables to cpu and the moniter after pressing the button of the cpu it makes 4 beep sounds and the moniter is blank and the green light blinks please advise
  • 36 Answers
Try unplugging the monitor cable frm the back of the computer & make sure the monitor is connectd to a known good wall outlet.....chk if it shows any self test on the monitor......if it shows anything thn it is related to the port on the computer or the video if it doesnt shw anything, u might hv to replace the monitor
Posted on Jun 30, 2008
Why the computer doesn't turning on but the green light is lighted
You may want to verify if the computer is the one that do not turn on. Please check if you see the fan on your computer is working and the LED in the mother board is lit.
IF the computer is working and no display on the monitor, despite seeing a green light on the monitor display, this means that monitor is well connected and communicating well with the cpu. Better check the inverter light on the monitor. Replace busted lights. These are responsible for the image you see in your lcd monitor. If the inverter lights are busted then you'll see only black screen.
Jul 09, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Hello, my dell 15'' flat screen moniter doeas not want to work. unlike us! LOL Any way the monitors green light comes on and thats it. no message, no error, just black death. help?
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Replacement bd:
Jun 07, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor light blinks no picture
(Please be advise that if you don't have the knowledge, the proper skills and the right tools to open the back cover of your monitor and replace its part...don't risk it...
Otherwise, bring your unit to a credible technician and avail of warranty if there is any.....) If you have guts.. then do the following steps..
You said your monitor will blink but no picture display... well, there are possible reasons why this problem occur..
1. Open the back cover of your monitor..Check the power supply section for possible loose connections and blown capacitors.. Resolder any loose terminal connection on the pcb. Check for any blown capacitor, replace the capacitor with exact value, and also replace any bulging capacitor..If you have successfully replace the parts you can try to turn it on and connect the vga cable in it to the video card of your computer. Turn on also the cpu, if the monitor led turn green and the display came out..that fixed it.
2. In case you have successfully repaired the power supply section and the led of the monitor stays green.. then the problem will be in the inverter board section....Turn off your monitor... open the back cover...on the inverter board section.. check and replaced burnt or overheating high voltage transformer..if one or more of this overheats, it is enough to affect the supply current from the power supply section and that may cause to blow your capacitor...If the ballast transformer is working fine the last thing to check is the backlight inverter (the light that illuminate causing display in your monitor) Replace any busted lamp.. that should fix the black screen on your monitor. ..
If you find this information very useful..please be kind to rate this solution and vote for this on the help below...thanks..
Much appreciated if you rate this help...thanks...
Jun 02, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mar 25, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
17 in dell monitor
Please disconnect the Monitor Data cable from Computer.
If you see Dell Colored bars, it means, monitor is working fine,
If still black, please ask for replacement, since Monitors have 3 years of warranty if not purchased with the computer.
Now connect the cable back to computer and turn the computer off by holding the power button on computer and turn it back on...
Blinking Green shows that computer is in sleep mode......
Hope this should resolve the issue.
Nov 06, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Green led light flashing on 700p proview flat panel and no picture
I have a similar problem.
Switching the screen off (front panel button) and on again after waiting a few seconds fixes it.
This is a recent problem, so I'm expecting it to get worse and worse until one day!!!!!!
Oct 03, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
Any high switching power supply of the same voltage and amperage rating will work for you. You may have to cut the end off of your old one and wire it to the new one to make it work but don't waste your money buying a specific power supply.
Good Luck!
Feb 16, 2008 | Computers & Internet
Dell 1503FP 15" LCD Monitor Logo
141 people viewed this question
Alun Cox
